Rearview Mirror Dim and Passenger Side Mirror Reverse Down? - SaabCentral Forums
Old 11th December 2011
earthbased earthbased is offline
Question Rearview Mirror Dim and Passenger Side Mirror Reverse Down?
Hello, the dimming rearview mirror no longer dims headlights (the button does not stay in a depressed position) and the passenger side mirror no longer points down when engaging reverse. Is this a mechanical issue or could a fuse that controls these have blown? TIA
(USA2000 9-5 SE V6 Wagon)
Saaber95er's Avatar
Saaber95er Saaber95er is offline
My Saabs: 1999 9-5 SE 5spd
Garage
Interior fuse box Fuse # 21 for the mirror; also shared with the audio system. Can you still adjust the mirrors manually? if not check fuse # 10, also if you have it fuse C. If these are good then replace the switch.
PEOPLE WHO TEST DRIVE A SAAB
USUALLY BUY ONE
Saab Owner/Driver since 1985,
firehawk618 firehawk618 is offline
My Saabs: 2001 9-5 aero
Fuse has nothing to do with switch staying in. Switch is bad.
Old 12th December 2011
Saaber95er's Avatar
Garage
I thought that most Saab mirrors were Auto Dim (sensor) Mirrors? Usually the ones with a switch also has a light (green or yellow) when on; I donít believe the switch stays in when auto dim is the on or off position. But if the OP says his stays in the switch would have to be used excessively to go bad but it is possible.
USUALLY BUY ONE
NotRambo NotRambo is offline
My Saabs: 2000 9-5 Aero
I have a similar issue with the mirrors not moving down when I engage reverse. I know the tiny button below the 4-way pad that adjusts the mirrors is supposed to angle the passenger side mirror downwards when I'm in reverse gear. I can adjust both mirrors just fine with the control, but no matter which gear I'm in, the tiny button doesn't work. I wouldn't use it much anyways (maybe on some tight parallel parks?), but I'm curious whether it's a problem with the switch or whether something else is going on.
Saaber95er's Avatar
Garage
Could be the switch they do go bad, when in reverse push the button and hold it for a few seconds and see if it moves; you can also check the connection to the switch.
USUALLY BUY ONE
Old 13th December 2011
domino's Avatar
domino domino is offline
My Saabs: 95 Aero
Don't you have to hold the button in for the passenger mirror to tilt downwards?
Saaber95er's Avatar
Garage
No, only for a second or two.
USUALLY BUY ONE
Old 14th December 2011
domino's Avatar
My Saabs: 95 Aero
I'm pretty sure on my last 9-5 you had to hold the button in. Mind you, it's been a while.
Neither pressing, quickly tapping, nor indefinitely holding the button while in reverse gear made either mirror budge at all, but ehhh... I don't think it's a big enough issue at all to warrant dissecting/examining the electrical connections to the switch and mirror. I know I'm about to hit the curb when people start fleeing in terror from the sidewalk.
domino's Avatar
My Saabs: 95 Aero
lol - that's one way of doing it!
Saaber95er's Avatar
Garage
If you must have that feature; change the switch you can get it cheap on ebay and it would take you less that five minutes to change.
USUALLY BUY ONE
Old 8th May 2014
martincote418 martincote418 is offline
My Saabs: 9-3 Aero 2004 Convertible
I have the same problem. I checked the switch module and it looks in very good condition. It's a differents resistors for differents button pressed. The tilt down button give about 2.93 kohms. Is it correct? I don't think the problem is the button.
Old 8th May 2014
The Ridge's Avatar
The Ridge The Ridge is offline
My Saabs: 2003 9-5 Aero Wagon Hazelnut Brown
Do your memory seat buttons work? The same module operates the seat memory and mirrors
Old 8th May 2014
The manual settings of mirrors works well. I never could memorized new seat settings even the tilt function worked well (I always thought the memory button does not works). The seat move to already saved position. Thank you for your help.
Old 14th October 2014
I fixed my seat memory button. It works fine. I can setting up new positions of the seat and the driver's mirror. But, the passenger mirror don't go back to the saved position. I think it's the same problem as the tilt downward. But I can adjust the passenger's mirror manually. So, it's not positionning motor's issue. Please help!
Old 15th October 2014
I finally found the cause of the issue. It's positionning sensor inside the mirror motors's assembly. I fixed the contact on the PCB and works fine.
Old 3rd March 2015
BaronHellJug BaronHellJug is offline
New Member
My Saabs: 9-5 SC 2,3t - 1xMY03, 1xMY08, 1xMY09
I have the same problem,
Would it be possible to give some more details? was it a contact in the mirror or in the control box inside the car? did you do soldering or just a cleanup of the connector?
All info would be most appreciated!
Old 4th March 2015
BaronHellJug, like I wrote it's inside of the mirror's motor assembly. If I remember correctly, you have to disassemble the PCB of the two small motors. Be careful for linear positioners. It was the outer route (near the edge) that was oxidized. I rebuilt the connection with a piece of thin wire.
When reassembling, you have to centering the linear positioners with geared arms.
It's a bit difficult repair. Good luck!
Martin
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
You may post new threads
You may post replies
Similar Threads
Driver's Side Rearview Mirror 'WHISTLING'... SAAB_State??? 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 10 29th July 2010 03:39 PM
Wanted: passenger side rearview mirror cover 2001nine-5 Parts for Sale/Wanted - North America 1 15th July 2010 10:21 AM
Wanted: passenger side rearview mirror/glass 2001nine-5 Parts for Sale/Wanted - North America 0 26th February 2010 10:12 PM
Passenger side mirror. kethgr 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 3 11th May 2007 04:42 AM
Passenger Side Mirror PRiCeLe$$ 9-5 Workshop 6 21st September 2006 11:36 AM
Powered by vBulletin® Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
