Review: 3M 08579 Leather and Vinyl Repair Kit - SaabCentral Forums
Go Back   SaabCentral Forums > Saab Ownership General Topics > Auto Detailing & Body Repairs
Auto Detailing & Body Repairs Discussions about auto interior & exterior detailing, products and autobody repairs.
Old 19th April 2015
swedespeed7's Avatar
swedespeed7 swedespeed7 is offline
My Saabs: 2008 9³ Aero SS, 2011 9-4X Aero
Default Review: 3M 08579 Leather and Vinyl Repair Kit
I just bought an '08 Aero. Noticed after I brought it home that there was a gaping hole in the driver's side bolster (was hiding because the seat was far back enough that the B pillar was hiding it). Don't ask me how it got there, because it's a weird place for such a large hole.
Rather than pay a place to do the exact same process, I decided to try it myself using the 3M 08579 Leather and Vinyl Repair Kit from Amazon. At $12 free shipping, why not?
http://www.amazon.com/gp/product/B0058WXNOK/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 http://www.amazon.com/gp/product/B0058WXNOK/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Reading the reviews, it's very apparent there was a lot of user error. So I took my time and followed the instructions with a few exceptions.
Since my hole was pretty substantial (2 inches), I used the thicker patching material. Cut out a piece bigger than the hole and slide it in.
The "vinyl adhesive" just appears to be Elmer's white glue in a small container, but whatever. I applied the glue to the patch and under the leather and waited for it to dry. Don't apply too much glue or it won't dry.
Finally, select the grain paper that most closely matches your leather/vinyl grain. Then mix the colorant until you get a close match to your factory color. The colorant is thicker than the glue, which is good for filling voids.
Then, instead of using the heat transfer tool and an iron, I used my wife's curling iron (set to 330 degrees F). Apply the paper right over the sticky wet colorant and then roll the iron over the paper firmly, being careful not to let the paper move. About 15-30 seconds for the colorant to cure.
That's it! Came out pretty well, it's not perfect but I'm happy with the results especially because the damage was in an inconspicuous area.
Before:
After:
Hope that helps anyone thinking about doing this.
Past SAABs: '93, '94, and '95 9000 Aeros, '01 Viggen, '09 2.0T SS
Old 19th April 2015
Diggs's Avatar
Diggs Diggs is offline
My Saabs: 2003 9³SS Linear; 2015 VW GTI
my wife would **** a brick if i used her curling iron to fix my car. good job.
The answer is almost always....Tech2.
You can either buy one or be a slave to your mechanic/dealer when you need repairs. Your choice.
Never have less than TWO working key fobs.
Old 19th April 2015
Haha. Thanks. My wife didn't even blink, she knows I take good care of her stuff. The iron never touches anything except the back of the paper.
Old 20th April 2015
Capriman86's Avatar
Capriman86 Capriman86 is offline
My Saabs: 07' 9³ 2.0T Titan Grey 60th BCB Stage 2
that came out better than I expected
~Jeff
2007 Saab 9-3 2.0T BCB Stage 2 Tuned / 2012 VW Beetle Turbo
(Mrs daily)
1986 Mercury Capri 5.0 T-Top 5spd / 1988 Ford Mustang GT
Old 20th April 2015
Thanks, I was surprised too. It didn't look very good after the first patching step, but the colorant/ironing step really finishes it out. It feels perfectly smooth to the touch and with the same texture as the rest of the seat too.
Old 6th May 2015
toxicavenger's Avatar
toxicavenger toxicavenger is offline
My Saabs: 2006 9-5 Sedan, 2006 Sportcombi
Congrats. I worked for an upholstery shop who use to do the same kind of repairs and believe it or not they held up really good.
Old 6th May 2015
Good to know
Old 29th June 2015
bdo888's Avatar
bdo888 bdo888 is offline
My Saabs: 08 9-3 aero
Default motivate!
Nice review! Hopefully this will motivate me to fix drivers side mini tear that drives me NUTS
Old 4th July 2015
verso's Avatar
verso verso is offline
My Saabs: 2005 9-3 Arc
It's definitely passable and looks a hell of a lot better than the gouge that was there.
Sometimes "perfect" just isn't in the cards, doesn't make sense or isn't practical, the time/expense makes it not worth it. Sometimes "good" is good enough.
Old 9th July 2015
bdonney bdonney is offline
My Saabs: 9-3
I'll have to try that too. My drivers seat on my 2006 9-3 has the vinyl part cracking pretty bad and the leather part. part you slide across. pretty sure those are the two most common areas. I have the parchment colored leather. I'll have to post pictures when I try this out.
I kind of always assumed those patches didn't work worth a damn.
Old 23rd July 2015
GoArmy GoArmy is offline
My Saabs: '03 9-3 SE Vert, '02 Viggen Vert Stage-1
Nicely done!!
Old 23rd July 2015
Originally Posted by GoArmy View Post
Nicely done!!
Thank you sir!
As an update, the repair is still holding up nicely.
Old 29th July 2015
brt brt is offline
My Saabs: 2003 9³SS Arc
Great job! I am really impressed with results and the fact that is holding up.
I love reading this forum!
Old 18th May 2016
1 year later and looks the same as the day I repaired it.
Old 28th February 2017
Almost 2 years later, patch still holding fine, looks the same as the first day it was applied, no color changes either. Good stuff.
DryBear DryBear is offline
My Saabs: 2009 Saab 9-3 2.0T Manual
Looks great! Have you used any leather care/conditioning products on the patched area?
Old 1st March 2017
Yep, just leather cleaner and conditioner as I normally do.
Old 3rd March 2017
SaabEC SaabEC is offline
My Saabs: 2003 Saab 9-3 SS - Vector
Man, this is a nice fix to a problem I fear encountering with leather seats.
Saab Story: '03 Saab 9-3 Vector
Old 8th May 2017
SilentJ20 SilentJ20 is offline
My Saabs: 2007 9-3 2.0T Manual
I'm debating trying something like this on the typical drivers seat bottom wear, but I'm worried about how it would handle actual contact. Your repair looks good still, but does it see any abrasion, rubbing or other contact? I wonder how it would hold up to me sitting on it and flexing it.
Old 8th May 2017
It doesn't see any contact, no. However, I'd have to say it feels stronger than the original leather/vinyl so it would probably hold up just fine.
For Sale: Lexol Leather Cleaner - Leather Care - Vinyl Rubber Plastic Protectant dantinne Parts for Sale/Wanted - North America 16 9th December 2013 11:56 AM
Just ordered my leather repair kit! Few questions beofre i get it.. saabsantiago NG900 & OG9-3 Workshop 0 30th October 2011 07:47 PM
Questions about leather repair kit.. PLEASE HELP ME saabsantiago NG900 & OG9-3 Workshop 9 19th August 2011 06:39 AM
Recommend me a leather touch up/ repair kit? Katsura 9-5 Workshop 2 24th July 2007 11:14 AM
What is Leather? What is vinyl? salemgreg NG900 & OG9-3 Workshop 2 3rd December 2006 07:06 PM
