9-5 aero mAir not meeting mReq - SaabCentral Forums
Old 24th February 2013
009-5aero 009-5aero is offline
My Saabs: 2000 Saab 9-5 aero 5spd BBS RK2 Blk/Tan
Default 9-5 aero mAir not meeting mReq
I have a jzw stage 1 9-5 aero and my mAir does not meet the mReq. It is usually around 1280 and my mAir may spike to about 1150-1200 but its usually around 1100. I have a new MAF, DIC, plugs (ngk 7's), BPC/APC valve, forge bypass valve, and bolt mod. Ive checked for boost leaks and it will hit fuel cut with the w hose removed. The only thing else i can think of is wastegate. Any thoughts?
Saabarina's Avatar
Saabarina Saabarina is offline
My Saabs: lots of them
that seems the same as mine roughly
Jssaab Jssaab is offline
My Saabs: 2003 Aero Hirsch "Clone"
that's pretty normal right there, Mact should jsut "chase" Mreq
well the weird part is that when it spikes to 1150-1200 its usually around 4500 down low it feels like it builds boost fairly slowly. The car barley spins tires in 1st and doesn't at all in 2nd, when i first got the tune it would very easily spin tires in 2nd and spike to about 1300
ji5mmy's Avatar
ji5mmy ji5mmy is offline
My Saabs: 2002 9-5; 2001 Viggen vert
Probably just adapting to your driving. Pull the ecu fuse, whatever number that is, and it should be back to how it was when you first put the tune in.
I have done that, does not help.
Old 25th February 2013
rabbit's Avatar
rabbit rabbit is offline
My Saabs: 2002 Vig BCB Stg2+
If you suspect the wastegate you could try and add a helper spring.
Sent from AutoGuide.com App
My Vig >> 345ftlbs 300hp <<
Old 26th February 2013
I got a spring from home depot and installed it. I worked for the most part. At the low end it sometimes spikes to 1400 but then goes down to about 1100 by 3500 and then soon after from about 3700-4700 its a consistent 1250. Other times though it will spike to 1300 and stay at 1250 for a good amount of time. Also in the high rpm i noticed some misfiring.
b207R air consumption, mAir at WOT Borntoroll 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 2 1st January 2013 09:11 AM
SoCal Meeting Feb 21st Abarth The Lounge 6 21st February 2009 02:34 PM
South Florida - Aero Meeting/Party/Dinner - Saturday June 2nd??? seiplax 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 0 18th May 2007 07:05 PM
Cannae get mair power, captain... Rentokil 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 11 6th March 2006 04:52 AM
NYSOC quarterly meeting! stephen9000T The Lounge 2 11th July 2005 12:27 PM
