Swapping ECU's - SaabCentral Forums
Go Back   SaabCentral Forums > Saab Ownership General Topics > Tech II Workshop
Tech II Workshop For all discussions regarding the Tech II onboard diagnostics tool.
Old 3 Weeks Ago
hunterstein555 hunterstein555 is online now
My Saabs: 2002 9-5, 1999 9-3 vert
Default Swapping ECU's
Hi
Just wanted to make sure I can swap in the ECU from a 2002 9-5 manual trans to a 2002 9-5 auto trans (with a faulty ECU), and if it's still as simple as entering the new immobilizer / VIN whatever
A couple tuners want $150 to do this for me, I'm half tempted to watch a bunch of youtube tutorials and buy a tech 2 clone already and do it myself since I need other Tech 2 stuff done to my other car as well
Thanks!
Old 3 Weeks Ago
EdT EdT is offline
My Saabs: 1997 900S Coupé, 2003 9-5 Linear Wagon
You have Tech II and TIS? I suspect that you will have to program the ECU. At the very least, it will need configuring.
Everything I've read indicates that the ECUs physically swap over. It's getting the right software on them that's the work.
Old 3 Weeks Ago
smokiebeverage smokiebeverage is offline
My Saabs: 08 93 1.8t
Have to considered https://txsuite.org/download/trionic-can-flasher/ and a $25 cable to clone the ECU
Old 3 Weeks Ago
summerof96's Avatar
summerof96 summerof96 is online now
My Saabs: ‘67 96, ‘02 9³ SE, ‘07 9³ SC, ‘11 9&#830
Yes, you can just marry the replacement ECM without programming it. The bin on the ECM won’t change unless you SPS. The TCM controls the auto trans.
Diagnostic - 2002 - 9-5 - Body - TWICE - Programming
Old 3 Weeks Ago
jvanabra jvanabra is offline
My Saabs: LOTS. :)
This is a great solution if the current ECM is readable! Although, $25 isn't the full story - you still need a power supply, some wire, a J1962 connector, and the OBDLink SX cable. Still, a lot cheaper than shop time or a Tech II.
Old 3 Weeks Ago
For a once off you can just do it in the car, no need to make any cables, just make sure the battery is fully charged or has a charger connected. Then all you need is the ODBLink which are around the $30 mark now.
Old 3 Weeks Ago
My Saabs: LOTS. :)
Not sure how that could work. The OG9-3 does not have CAN at the OBDII connector, you need to intercept it at the connector behind the glove box and get it to the OBDII connector in order to use the OBDLink cable.
Old 3 Weeks Ago
I might be needing new glasses missed the model in the first post!
Old 3 Weeks Ago
This is for a 9-5 2002
You guys are saying I can do this without a tech 2?? Anyone have a link to somewhere with a little more detail on this?
Old 3 Weeks Ago
summerof96's Avatar
This is true.
Old 3 Weeks Ago
Have a look at https://www.trionictuning.com/forum/viewforum.php?f=40 you will need to make an account, but all of the information can be got from the T7 section with a bit of reading around.
Old 5 Days Ago
So I actually own a Tech 2 now, and I understand 'the basics'
Anyone have some advice on how to go about swapping ECU's with it? I posted on the Trionic forums about using an OBDLink but got no replies
The one thing I'm concerned about is the ECU I'm putting in is from a manual '02 linear and it's going in to an automatic '02 linear
Old 5 Days Ago
Mimmi's Avatar
Mimmi Mimmi is offline
My Saabs: Hirsch fleet: 2*9-5 + 9-3
In exchange of those ECUs, you only need to reprogram IMMO code.
Old 5 Days Ago
How do I do that exactly? By plugging in to my computer and editing the code somehow, or can it be done by just putting in the new ECU and clicking "Immobilizer" under TWICE?
Old 5 Days Ago
EdT EdT is offline
I hope to try this soon. This ought to cover it if the ECU is otherwise suitable:
https://saabwisonline.com/c6/9-5/200...yl/to-fit-108/
Personally, I plan to do an SPS update for the spare ECU I have, then go through the immobilizer programming.
Old 5 Days Ago
My Saabs: LOTS. :)
T5 and T7 will work with either transmission - they work in manual transmission mode when there is no signal from the transmission range sensor, then "become" automatic ECMs when there is a signal. The programming is all the same. Like Mimmi said, the only thing you need to do is program the immobilizer code.
Old 5 Days Ago
So when I was fooling around on tech 2 for the first time today, I hit 'Immobilizer' under TWICE and it 'immobilized' the car. Then I did it again and it 'remobilized' the car
So all you guys are saying is plug in the new ECM and then do that same thing?
I did read that WIS instructional but it definitely felt like I was missing a step
Old 4 Days Ago
Mimmi's Avatar
Yes...
Old 4 Days Ago
summerof96's Avatar
Just did this within the last couple weeks. Converted my b205 to forged b235. I had a spare Viggen ECM laying around. Plugged it in, hooked up the Tech2 and programmed the immobilizer, then cleared codes. It fired right up!
Old 3 Days Ago
Well..that was easy! New ECU went in and programmed in 5 minutes. P1663 cleared which was why I put in the new ECU. Tech 2 has 1/3 paid for itself now!
HTML code is On
