1997 Saab SE Turbo Fuel Pump Ground - SaabCentral Forums
Old 2 Weeks Ago
'97 Saab SE Turbo's Avatar
'97 Saab SE Turbo '97 Saab SE Turbo is offline
My Saabs: Black on black '97 Saab 3-door SE Turbo
Default 1997 Saab SE Turbo Fuel Pump Ground
Can anyone point me to where in the trunk the fuel pump ground is? I seem to have a problem when shifting the 5-speed manual into reverse - the engine starts missing and wants to stall. It doesn't do this in 1st through 5th, so I think that the reverse lights are taking power away from the fuel pump. Today, I also found out that while driving normally and switching on the rear window defroster, the same thing happens. So, I think there may be a loose ground in the rear of the car. Maybe the G404 below left rear light cluster.
Also, can anyone tell me exactly where it is? Is it under the trunk liner, inside the tail light housing, etc? I assume that it's some kind of stud that sticks up.
As a last resort, I can run a jumper from the fuel pump to a good ground for testing purposes.
Well, I found a workaround. I pulled the reverse light connector off the transmission and removed the 30A fuse for the rear window heater. So, I shouldn't have to worry about using reverse or having the rear window defroster coming on if I use the windshield defroster. But, I would still like to find, clean and lubricate that G404 ground point.
TIA Ron
Old 2 Weeks Ago
jakejm79's Avatar
jakejm79 jakejm79 is offline
My Saabs: None at the moment
The ground point is on the floor of the trunk, on the drivers side rear corner (kind of where the CD changer would be mounted). Its behind/under the carpet so you would need to pull it back.
Definitely seems like classic bad ground problems. I like to relocate it up on the side of the trunk (like where the antenna mounts/ground to).
Old 2 Weeks Ago
Jake, thanks for the information.... Ron
Old 2 Weeks Ago
Jake, does this mean that I have to remove the CD player to get at the ground point? I currently have some WD-40 soaking into the 4 CD player mounting screws... Ron
Old 2 Weeks Ago
OK, I finally found it. It was a "loose" ground cable with a washer & nut (maybe 10mm) at the furthest point back in the corner of the floor on the drivers' side of the hatch. I assume that it was bolted through the floor at some point before the floor rusted away from below. Anyway, I took a clip lead and grounded the cable to a clean ground and everything (all lights and fuel pump) seem to be much better. I'm going to connect that cable to a good ground point with a lug, sheet metal screw and washer.. Ron
Old 2 Weeks Ago
jakejm79's Avatar
Glad you found it, While the CD changer doesn't obscure the ground point directly, it will stop you from moving the carpet to gain easy access.
2001 Saab 9-5 V6 3.0 Turbo - Starting Problem elindber 9-5 Workshop 0 14th January 2014 12:05 PM
What is the problem with my AERO?? beachrights 9-5 Workshop 25 29th December 2012 11:40 AM
Fuel Pump Issue: 1997 900s Maineguy NG900 & OG9-3 Workshop 9 2nd June 2011 04:46 PM
1984 Saab 900 Turbo 8 Valve - No Start - FUEL ISSUES S900t8v C900 Workshop 13 12th April 2010 09:32 AM
2 threads in one: Fuel pump failure? AND What may have killed my turbo... jonboy545 C900 Workshop 1 3rd April 2006 02:28 AM
