Oil Filters - Page 2 - SaabCentral Forums
Go Back   SaabCentral Forums > Saab Ownership General Topics > Engine Oil, Lubricants & Fluids
Engine Oil, Lubricants & Fluids Discussions about engine oils and all automotive fluids
Old 24th February 2019
zinfandel's Avatar
zinfandel zinfandel is offline
My Saabs: 04 9-3 Aero SS, 08 9-3 Aero SC, 11 Vert
Not sure why a manufacturer would make a good filter only in their top end filter and the rest would be lower quality. You are either a quality brand or not. You should not make crap for your lower end
Currently 2004 Aero SS, 2008 Aero SC,2011 Turbo 4 Vert Previously 2000 9-3, ,1996 900S , 1972 SAAB Sonnet, 1986 900S,1978 99T,1975 99 Hatch,1973 99 .
At least one SAAB in the household since 1973
Old 28th February 2019
300sdl's Avatar
300sdl 300sdl is offline
My Saabs: 2003 9-5 2.3t Wagon
if it means anything to anyone I liked the wix xp filter. it's my nature to use the oem parts, but you know the wix xp filter is respectable and it's parent company mann hummel is reputable. i use mann filters in my mercedes. i have mann air and cabin air in my saab. hengst is great. necht is good too. i have necht for my fuel filter on my diesel mb. as for oil valvoline for the domestics and liqui moly for the imports. i only use synthetic. i stopped using conventional some time ago.
  #23
Old 4 Weeks Ago
radarwill radarwill is offline
My Saabs: 1997 900SE Talladega
Default Bosch Premium
I've used them all my life and have been very happy with them.
  #24
Old 4 Weeks Ago
Saabohème Saabohème is offline
My Saabs: 2008 9-3 SS 2.0 6Spd JZW Stage 1
Yeah, me too. In 1978.
  #25
Old 4 Weeks Ago
qwikredline qwikredline is offline
My Saabs: 2007 9.5 Combi Sport
lol. 1980 here...
  #26
Old 4 Weeks Ago
SilentJ20 SilentJ20 is offline
My Saabs: 2007 9-3 2.0T Manual
if it means anything to anyone I liked the wix xp filter. it's my nature to use the oem parts, but you know the wix xp filter is respectable...
I use Wix also. It's the only filter brand I can find in local auto parts stores that I trust (no ACDelco or Bosch cartridges). Found it recommended in many previous posts in various forums for saabs.
  #27
Old 4 Weeks Ago
jvanabra jvanabra is offline
My Saabs: LOTS. :)
I use Wix XP as well in all 12 cars. Well, except the XJR because Wix inexplicably doesn't make an XP version of their filter for it.
  #28
Old 4 Weeks Ago
So, I just did some digging around. Apparently, the XP filter line made by Wix is designed for longer OCI (Oil Change Intervals) and does not filter quite as well as the base Wix filter. Not that it doesn't filter good enough, just that to make it last longer between oil changes it can't filter as well or it would get plugged up. If you're changing your oil at regular intervals, the standard Wix filters better. The XP doesn't mean better performance or better quality, necessarily. Just that it lasts longer.
This is what I found, and makes sense, however I want to add the disclaimer that a lot of this stuff is debated, and Wix isn't known for sharing specs about their filters.
  #29
Old 3 Weeks Ago
My Saabs: LOTS. :)
Mmmm… I think you're referring to the 35 micron vs 23 micron statistic, true? For all intensive porpoises, that is not a substantive difference. The capacity is almost double on the XP filters. Also not substantive unless you have crazy long OCIs (or, I guess, a really wrecked motor!).
The advantage for me with the XP line is the synthetic media and silicone anti-drainback valves. I have a dozen cars and only drive about 10,000 miles annually (excluding the motorhome), so sometimes I have cars that do very little between annual oil changes. I take solace in the security of synthetic bits that won't fall apart if, you know, maybe a car ends up going 18 months between oil changes. Also, with a fine selection of boosted cars that tend to be driven hard, higher temperature tolerance (from synthetic materials) is probably a worthwhile benefit.
In the case of the Aero (and, I wish, my Jag) the wire-backed media is a nice addition since I don't have to worry about the filter element collapsing, which I've seen on cheaper filters.
I order the XPs from rockauto where they are usually between $4 and $7... cheap enough that it doesn't factor into the buying decision at all.
Edit: Crap, I lied. I don't use an XP in the '67 Fleetwood either, because it's not available. Nor in the Falcon - it is available, but who needs a fancy filter on a 60 year old 100hp inline six? Nobody.
Edit 2: Not that anyone cares, but happily my lawn mower and the generator on my motorhome both use the same filter as the Saabs. So when I buy "oil change specials" at Autozone and get a "free" filter, I get a Saab-sized filter and put that crap on a small motor. So good. So savvy.
  #30
Old 3 Weeks Ago
My filter is the 57082 cartridge style, and only the non-XP has a micron rating of 18. The XP doesn't have a rating, so I've been unable to compare. Is the XP in your filter the 35 micron? Not sure what difference that makes vs the 18 of my particular filter. Hard to find info on filter tests, unlike the abundance of oil comparisons.
I've personally never had an issue with any filter collapsing, but I've heard of it happening to others.
If the price isn't very different, then peace of mind is a big deal.
Oil, oil additives and filters. Terpodion 9-5 Workshop 19 1st September 2017 11:53 AM
After Market Oil Filters and Oil jimfellows 9-5 Workshop 11 17th July 2009 04:13 PM
New GM oil filters vs. Saab oil filters (was "My C900 is not a GM! Its a Saab") alexis C900 Workshop 24 17th March 2006 06:11 PM
Foam Mushroom Air Filters vs Standard Cloth Cone Filters dasaabguy NG900 & OG9-3 Performance, Mods & Tuning 0 23rd March 2004 05:00 PM
knr filters vs jr filters Saabster93 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Workshop - ALL Engines 7 30th June 2003 06:02 AM
