oil pump piston repair - SaabCentral Forums
Old 13-04-07
blueranger blueranger is offline
My Saabs: 1989 saab 900 convertible
Default oil pump piston repair
i just bought a 1984 saab 900 s and the fellow tells me that the
problem with the car is the oil pump piston and spring. he has
removed it and cannot get it back in...and thinks he may have lost
the pieces..
1. where can i buy the oil piston, and springs and cap...?
2. Can it be replaced without removing the engine... ?
3. can it be replaced without even loosening the engine?
4. Anyone ever done this before?
Old 13-04-07
900t's Avatar
900t 900t is offline
Saabista
Oh man I did that once...
took me a few days to get it back in The spring is very stiff and it's hard to thread in.
You can definately do it, just work harder putting it in. You don't need to do anything but removing the LF wheel makes it easier to see. Look near crank pulley.
Old 13-04-07
Default secrets
where could i buy the whole item... i may be missing the screw as well...
how about pressing it in... any ideas....
