replace remote control battery - SaabCentral Forums
Old 12th April 2007
coolsaab coolsaab is offline
My Saabs: 2000 95 2.3t
Default replace remote control battery
I have 2000 95, the remote control is the kind which buttons on the same key.
I need help to how to replace the battery, there is a pin size hole at the side, but can't seem to be able to pin it down and release the cover.
Does anyone have done that before and know the trick to releaes the cover of the key?
Thanks in advance for any help.
Old 12th April 2007
sierra-papa-golf's Avatar
sierra-papa-golf sierra-papa-golf is offline
My Saabs: 1991 900 SPG/ 2001 9-5 Aero
What size pin are you using? I read the owners manual today and I believe it must be <1.5mm, but am not sure. Check the manual to make sure, there is also a procedure to turn the remote back on.
Old 13th April 2007
guitarguydudeperson34's Avatar
guitarguydudeperson34 guitarguydudeperson34 is offline
My Saabs: 2000 9-5 2.3L
did you take the screw out?
....oh that kind nevermind then
Old 13th April 2007
luv2drinkcoke's Avatar
luv2drinkcoke luv2drinkcoke is offline
My Saabs: Suzi - 2001 95 Arc 2.3t Auto
The cover might just be stuck.
You need to use something small to slide into the hole on the side of the fob to release the back cover. Be very careful not to push to hard or you could break the clip. If the cover does not pop open when you push the clip in, use a second pin to gently prise the cover up while pressing the clip.
Again i must say...be very gentle, the clip breaks easy! If you still can't get the cover off, you should take it to the dealer and ask them to remove the cover. You can then replace the battery yourself, say Thx and head out the door.
Once the battery is replaced, you must (when in range of the car) press the unlock button 4 times to reinitialize the remote to the car.
Old 13th April 2007
MacNoob's Avatar
MacNoob MacNoob is offline
My Saabs: 01 9-5 Wagon (RIP); 05 9-5 Aero (gone)
You can't use a pin or paperclip or anything like that in that hole. You need a screwdriver or small pin punch or something very strong, because that sucker is freaking tight in there. Get a helper (or third hand) with a small screwdriver, push your pin punch into the hole and have your helper gently pry the back off the key.
Next step after you swap the battery is getting the car to recognize the key. I've never been able to make it work (always need dealer to Tech II it) but you're supposed to be able to push unlock several times to reprogram it.
Old 14th April 2007
thaks for the tips, still can't get the cover pop up.. So went to the dealer's auto part department, ask the services guy pop it open and swap the battery for me, press unlock button 6 times, and the remote works like a champ...
Old 14th April 2007
Did you watch how the part's guy opened it?
If you did, describe for us. We'd like to know...
Old 15th April 2007
No, he took it back to the Technician to replace it, he just mention need to use the right tool and pry the back cover harder to get it off the key. hmmm... I should ask the guy in more detail.
Old 15th April 2007
That would be great if you asked on your next visit to the dealer. It would be good information for the next time you have to replace a battery, but also for the rest of us!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
