Check engine light..no code reading - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > 9000 Workshop
9000 Workshop 9000 (1985-1998) Technical Forum
Old 11th April 2007
njdenis_2001 njdenis_2001 is offline
Default Check engine light..no code reading
My 93 9000 non-turbo has been getting regular cel readings. When I try to get the codes it doesnt do any kind of blinking whatsoever. The symptoms when the cel comes on are: Idle drop to 700rpms..sometimes followed by a surge of 1200rpms.The throttle seems to stutter sometimes..and on some weeks no problems at all. I would rather not go to a dealer due to lack of money and lack of time off from work. Any input is helpful. Thanks ps are there one or two o2 sensors on this model?
Old 11th April 2007
yaofeng's Avatar
yaofeng yaofeng is offline
My Saabs: '94 9kcs, 9kcde, '95 9kcse, all turbo
What step did you take to get the code? Did you turn the ignition key to start short of cranking the starter and wait for the code to flash?
AIM:yaofeng4249
'94 cs, '94cde, '95cse, all turbo and 5 speed all gone,
4 bimmers now '95 525i, '94 540it/6, '01 540it, '03 325i
Old 11th April 2007
prionailurus prionailurus is offline
My Saabs: '06 9-3ss V6 aero
Assuming the battery hasn't been disconnected for any reason (as then you'd need to do an adaptation run)...renew or clean & re-gap the spark plugs, clean the IAC valve. These are cheap things, other than that, try swapping with a known good DI.
Old 11th April 2007
I did the just short of cranking the engine to try to get the code. That is the only method I know to use
Old 11th April 2007
Is there a way for a non-mechanic to test the di and see if it is good or not? If it makes any difference the car usually starts up quickly and plugs were changed about 300 miles ago
Old 12th April 2007
abusot abusot is offline
I have the same car, it had exactly the same problem.
The connector to the AMM (air mass meter) lives out in the weather and the connection got dirty. Disconnect, spray with contact cleaner or WD40 and reconnect.
If the CEL goes on and stays on, and the engine won't hold an idle on a cold start, and occasionally stumbles when warm, then its probably the AMM itself.
Old 12th April 2007
great, I will give that a shot. Do you spray where the meshlike part or literally the connector/wire part?
Old 13th April 2007
Just disconnect the connector, its held on by a big clip, separate the parts and you will see a multi pin electrical connector, spray that, connect and disconnect several times to make sure the contacts are clean, put it back together.
Old 14th April 2007
Its been one day-ish ..so far its running pretty well after doing the cleaning..thanks for the input
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
