my car rocks... and it won't stop -- Help! - SaabCentral Forums
Old 9th April 2007
itsHerFault itsHerFault is offline
New Member
My Saabs: 2001 93 and 1999 93
Question my car rocks... and it won't stop -- Help!
I was driving down the road today, and when I decided to change the station... it didn't work. I was worried that it was a problem with my steering wheel controls. But then I tried the buttons on the radio... nothing. I can't change the station, volume, band, balance... nothing. And it won't turn off! I happened to be listening to a classic rock station... so the car just keeps on rockin'. I tried turning the car on and off a couple times, taking the key out, opening and closing the door. I went to a store, came back out... the radio was still on... started the car drove home... the radio is still on.
I was going to start pulling some fuses to see if that would reset it (there's no ctrl-alt-del on this thing), but thought I should try to get some advice first.
Thanks in advance...
Old 9th April 2007
NVSBANDIT NVSBANDIT is offline
My Saabs: 1995 saab 900 SE convertible 2.0T
HAHAHAHAHA
your saab is playing mind games with you DONT LET IT GET TO YOU KEEP ON FIGHTING!
Old 9th April 2007
redrum's Avatar
redrum redrum is offline
My Saabs: 1997 900SE 2.0t
Might as well try pulling the fuse for the radio and let it sit for a few minutes to reset. Be sure you have the anti-theft code before you do this, though.
Old 9th April 2007
Old Goat's Avatar
Old Goat Old Goat is offline
My Saabs: 1997 900 se turbo
Does his version of radio even have anti-theft codes to put in? I believe his radio is just married to the system, so no code needed.
Maybe the radio just wants to groove a bit. No new age or pop, after all SAABs are in a class all to themselves.
I would give a try to resetting it with the fuse pulling. It may be a short that is preventing any other signals from reaching the radio control though.
Good luck.... and keep on rockin'.
Hey! Who you calling OLD?
Old 10th April 2007
New Member
Default pulled the plug... but why did it work?
Ok, so I pulled fuse 13 and the radio went off. I turned the car on and off a couple times and it seems to be working ok.
So, any ideas on root cause or whether I should expect this to happen again?
Old 10th April 2007
hkayssi hkayssi is offline
My Saabs: 1997 900S
That is one wierd radio! and likes classic rock. Reminds me of the movie Christine
I have a hunch you'll need a new radio Start with checking if all 3 fuses are ok
Old 10th April 2007
Twitchie Twitchie is offline
My Saabs: none
just dont sit in the car too long
at least the car likes good tunes
try disconnecting the battery for a bit also if the problem arises again
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
