Creaky suspension - SaabCentral Forums
Old 04-04-07
CTDUNNONE's Avatar
CTDUNNONE CTDUNNONE is offline
My Saabs: 2002 9-3 SE JZW STAGE 4+
Default Creaky suspension
Hi,
I hope someone can help me with this becasue my local garage isn't getting anywhere. On cold days my front suspension creaks like crazy when going over bumps and i was wondering what the cause was and if it is fixable. The noise occured even before I had all new Koni suspension installed including all new bushings. The creaking seems to be coming from the front two wheel wells and just infront of my feet, the noise is very loud and somewhat disconcerting on cold mornings. Any help or opinions would be greatly appreciated. Thanks.
Chris
Old 04-04-07
Dman5150 Dman5150 is offline
My Saabs: 1996 900 SE Turbo
i'd recomend tightening the 6 sub-frame bolts on the bottem. did mine 2 days ago and no more creaks over bumps. mine were real bad when i accelerated and braked. I thought it was the bushings or struts but it wasn't. 3 of the bolts were loose only about a half turn each but it made such a difference when i re-tightened them.
Old 04-04-07
Old Goat's Avatar
Old Goat Old Goat is offline
My Saabs: 1997 900 se turbo
Plus, these cars are known to do that.
If you change the various bushings to poly it will quiet it down. You probably notice that after the car is running a while it is fine.
Hey! Who you calling OLD?
Old 04-04-07
Kolhoznik's Avatar
Kolhoznik Kolhoznik is offline
My Saabs: 1999 9-3
It is normal in cold weather.
Old 04-04-07
iGOTaSAABstory4u iGOTaSAABstory4u is offline
My Saabs: 2002 Viggen Conv.
ya happened to me too. it was about -10*F when it happened and it sounded like it was metal on metal. this is normal for Saabs, and most cars.
Old 04-04-07
DanS DanS is offline
My Saabs: 2007 9-3 2.0T Past: 2001 9-3
Mine also did that in cold weather. Its really aggravating because most other cars don't do this. Its puzzling since Saab's are designed and built in a cold weather country.
Old 04-04-07
Old Goat's Avatar
Its probably the material of the bushings. Change them to poly and the problem goes away.
Old 05-04-07
hkayssi hkayssi is offline
My Saabs: 1997 900S
Mine does that too when the weather is too cold. After a few minutes it goes away. The service department told me that's normal and all SAABs or almost all do that when cold. After a couple of minutes of driving it goes away. If it's persistant and doesn't go away you may have a problem
