Anyone got one of these they want to 'rent' out to me for a couple of days? I don't fancy investing £30 in my own and have no idea where to start making up special wires with switches in etc - I'm more a plug and play kinda guy
I assume they will help me reset the ECU - thats what I am aiming to do. |
| Sponsored Links | ||
Advertisement | ||
if you want to reset the ecu, just dissconect the battery for 30 minutes....
as for making a special tool.... its so ludicrusly easy i will try and take a picture of mine when i get home - it took a matter of seconds to put it together and required no soldering at all G
"we can allow satellites, planets, suns, universe, nay whole systems of universe[s,] to be governed by laws, but the smallest insect, we wish to be created at once by special act" - Charles Darwin http://www.nicecupofteaandasitdown.com/ http://www.saabcentral.com/phpgallery/Gs-little-Saab |
Thanks G, I would appreciate seeing a picture.
As for just disconnecting the battery, according to various posts that does not work on the later c900s? Happy to be proved wrong though. Nick |
Think my son has one in MY garage! Let me know and I,ll dig it out.
Hey Anorak, would be greatful for a lend, thanks. Send me a PM and we can sort out me paying for the postage, 'rent' etc. Or if he does not want it anymore happy to buy it. Cheers Nick
Making a test lead for that is about as easy as it gets, it would probably take about one minute to twist the wires onto the clips/switches/etc
The faster you go, the more you see. |
Fair enough, but then if you factor in that I don't have any of those things so would have to go and buy them...
...and then reading the instructions I was concerned how easy it might be to miscount the flashes, so thought that if someone has developed the correct tool already (and I can lay my hands on it cheaply) then why not use it Gunson tell me that "We did make a G4159 that would fit a Saab 900 with a B202 engine 1988 to 1993 with Bosch LH 2.4 ECU system (Bosch ECU not injection). 10 pin DLS. These are very specific and won’t deviate." So I am going to check mine out for that if ANORAK finds his Gunson |
Does the thing tell you what the codes are?
I guess it will tell you what the codes are, but not what they MEAN. The sales blurb say that there is a lookup table in the box to do this.
To be honest I was just interested in resetting the ECU and see if it made any difference to the car. Andy at the SaabScene RR day did same on his 9000 and said it was like driving a different car. |
It would be very convenient, but you could try what G said, with the battery disconnect...
What's the rationale for resetting the ECU - does it make it resample the fuel system or something?
Even if I disconnect the battery, which some posts say don't affect later cars, I have no way of knowing if it reset the ecu without getting the tool or making up the wire anyway.
>>rationale Just like I say, a 9000 owner I met recently recommended it. Looking through the tech stuff and posts about ECUs does not seem like it does it any harm (famous last words |
nick... send me your address in a PM and I will post you down mine that i made, along with some seriously easy "how to's" that i have taken from the Lucas Manual... (that Gunson tool you mentioned, only seemed to quote refence to the Bosch ECU's, despite also saying it went up to 1993
It really is just a case of clipping one end of the switch to a ground, the other to the ECU test spade (usually lost somewhere bewteen the power steering resovoir, extra relay pod in by the O/S wheel (have a look in my Fotolog or SaabPics.. theres a pic in there somewhere).... when you have connected it up, follow the instructions. You get a series of flashes that i think tell you the thing is connected, then a series of flashes that are the fault code.... the instructions have a table of references for deciphering them, and a diagnostic section for common faults..... in fact, i think the Lucas Manual is electronically available on this site somewhere.. if not, Matthew has it on his domain ok... PM me your address, and i will post it off tonite - just post back when you are finished G
Cheers G
pics of wher the ECU socket is (i say socket.... its just a female spade connector
also, PM me your email, and i will send you the Lucas Manual in PDF... just found it! G
I never even knew that was the code pulling wire, I have never needed to pull codes for anything, the Lucas has been rock solid. |
no it aint - unless i got my biology wrong and im actually a lady
![]() male spade ....................................goes inside female? ![]() G
Holy cricket sheit your right From the first attachment it looked flat, I need new specs |
[QUOTE=drg23]no it aint - unless i got my biology wrong and im actually a lady
male spade ....................................goes inside female? G, in this big wide world .................. not always so !!!!!!! |
steve... you just made my morning... cheers mate
G
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
