| Saab 9-5 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9-5 |
just finished the FMIC install. took all day but it was fun. heres a link to my cardomain page with full instructions for anyone who wants to do it.
the only hard part was fitting the piping to the turbo... you can get to it from where you fit your oil filter. good luck! http://www.cardomain.com/ride/2499881/5 Last edited by guitarguydudeperson34; 11-04-07 at 07:27 PM. |
| Sponsored Links | ||
Advertisement | ||
Very nice work fella.
Very nice job, great to have a pic tutorial!
yea i've heard a lot of people wanted to do it but needed more info. i think all together the job costs about 330 dollars. everything off ebay.
Good work.
Almost exactly the same setup as mine. |
Excellent write up guitarguy..... (your user name is toooo long
Thanks for the contribution to the boards. |
Well done, that is inspiring!
Where did you get the piping and what's the diameter?
I'll do this same time I replace my turbo next weekend
99 SAAB 9-5 115K miles - 5spd 17" GM Factory Wheels Intrax Springs K&N Magnaflow Exhaust FMIC BSR Stage 1 ------------------------------------------ 99 SAAB 9-5 112k miles - Auto (wife) 16" BBS Wheels ------------------------------------------ 99 SAAB 9-3 Vert 82K miles - 5spd Koni/Bilstein Suspension 22mm Rear ARB Front ARB Poly Bushings Poly Engine Mount Poly Trans Mount 6-Point Sub Frame Brace ITR Front Lip 18x8 - 225/40/18 9000K HID |
i got the piping off ebay. it's 2.5" just search for turbo or intercooler piping
hey! someone already did that to my car
good for you
Haha christ, what an ending to a thread...
Hey, I have a question for anyone here that might know: Does the TD-04 turbo use bigger piping? If yes, what size? And also, does going from 2" to 2.5" cause any pressure loss problems? Have you noticed any gains guitarguy? I have this nervous feeling that putting on a IC that is smaller than the stock one will cause a loss in power and efficiency... Can someone please prove me wrong... please? lol |
I've got the '04 Aero front end, so I've got some room to play with width-wise, but not height-wise really. Oh and BTW I'm not keen on installing a front mount and leaving the stock IC in or even cutting the core out JUST to retain usage of the mounting brackets. If I'm gonna do it I'm gonna do it right. Cheers. |
Sorry if that seemed out of order and confusing, I'm kinda just throwing out points and questions. |
well done dude.. and on behalf of everyone on the forum, thanks for taking the time out to explain all the steps.. awesome!!
I have seen no major difference with the AC off, no matter how hot ( up to 100) still 1 or 2 lbs less. The drop-in is huge, so the area to dissipate is large. Oh yeah, I have the 2000 front end so I think that may affect it as well. |
ok first of all i have noticed a big difference after installing this. when i took it out for a test drive and hit the throttle i got an instant kick in power almost like a supercharger, its nice. and it now pulls all the way to redline which my puny lpt didn't really do before. it just snowed last night (damn it) but when it melts i'll do some whp tests, 1/4 mile runs and 0-60 runs and put it up against my numbers i did before and see if theres any changes.
i know the new one is smaller but think of the differences; the stock one is behind a whole bunch of crap thus hindering its ability to disipate heat. it also has a 90 degree turn in the piping goign to the throttle body. not a 90 degree bend like in the new piping. this turn can cause turbulence in the air exiting the IC thus causing a kind of block in the max flow possible through the piping. and we don't want that. the new one is right up front with nothing in front of it so the heat can be dissipated much easier as fresh air passes through it. from the pictures you can see the nice smooth bends in piping thus allowing the air to flow freely through the IC and not slowing down. this size IC, although smaller, is able to keep up with a lot of power. i will upgrade to a bigger size, maybe 11 inch instead of 6, if i go for like 400+ hp eventually (i wish haha). and as j006 said its ahead of the hot ac compressor now. so no hot air from that is passing over the IC now. also i think that leaving the stock IC in place is a good idea. for one it's a lot easier than taking it out and making new brackets, second this adds to the weight over the front wheels which is good to reduce wheel spin on our FWD babies. the new FMIC system, however, only weighs about 30 pounds total. if you do keep the stock one, shove a towel in the ends so no crap gets in if you want to sell it and/or return to stock (for some crazy reason). plus it looks bad ars! |
oh yea i have the 2000 fornt end too and it actually comes about an inch below it. can't notice it though once completly installed. i want an 04 or aftermarket one
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
