starting problem - SaabCentral Forums
Old 19-03-07
saabspg18 saabspg18 is offline
My Saabs: 1988 900 SPG
Default starting problem
hello, this morning i went to start my 88 900 spg and got nothing all i got wa a face full of dash lights ie. oil batt light etc. its not turn over or anything i lloked at the fuses but am not sure which one is the starter fuse. please help! thanks~
Old 19-03-07
jetman jetman is offline
My Saabs: 1984 T8
If all you got was a click, I'd suspect a dead battery or poor battery ground.
Old 19-03-07
um not even sure i heard a click but yeah it didnt do anything. i checked all the fuses the only one being out was the fog lamp fuse replaced it anyway. i will put the batt on the charger. thanks for your help!
Old 19-03-07
hooked the batt up to the charger and it read 10v. im not sure if that qualifies it as dead? i put it on the charger anyway. what is the battery ground connected to?
Old 19-03-07
My Saabs: 1984 T8
Should read at least 13v I believe.
Old 19-03-07
SteveTheFolkie's Avatar
SteveTheFolkie SteveTheFolkie is offline
My Saabs: 1987 900 8V
- not dead - but not exactly dancing - once you get it started check the charge coming out of the alternator - check your grounds - and (if they all check out OK) try to figure out what you left on last night ....
Old 19-03-07
hahaha no its not dancing haha k i will check those thanks!!
