Vented vs. non-vented: differences? - SaabCentral Forums
Old 13-03-07
Tyler's Avatar
Tyler Tyler is offline
Default Vented vs. non-vented: differences?
On my 85, I have non-vented front rotors. Am I right in assuming the only difference between the old style non-vented and the old style vented brakes are the rotors themselves and the yoke that slides on the caliper? Does that make sense? Thanks in advance.
-Tyler
Old 13-03-07
Dans_t16s Dans_t16s is offline
My Saabs: T16S
IIRC The vented front disc requires the wider yoked sliding caliper ( almost impossible to find now!) AND narrower width disc pads ( also as rare as hens teeth!)
Its just a bolt up and drive job (if you have the parts).
Dan.
Old 13-03-07
kemosaabey kemosaabey is offline
My Saabs: MB 190E ex 9000i 900i 900GLi T16Sx2 99x3
I have the vented discs - I've used standard pads with no problems.
Maybe there was a difference but I guess it's a case of 'one size fits all' these days....
Old 13-03-07
Rodentmaster's Avatar
Rodentmaster Rodentmaster is offline
My Saabs: Rip:'86 EMS Now? 2x 93 2.1 5dr & Vert
The pads were originally......
made of different compositions, non vented had softer compound while the vented used a slightly harder compound to make up for the reduced depth (thickness) of the pad. I found that the non vented rotors were prone to a 'higher than average' occurance of brake throb or grab/ warpage, however you wish to describe it.
Generally, I found after a hard drive and workout on the brake pedal then applying the handbrake, I would usually begin to notice the brake throb a few days later. That to me was one flaw in the front handbrake arrangement, the front pads, always the hottest, being compressed into the hottest disc where, at the pad/disc contact area, would be the last point to cool down and so create an uneven heat cool cycle across the rotor.
I'm not seeing this occur at the moment with the current car thankfully.
Woah! Don't expect men to talk to your face if you patronise that establishment!
RodentMaster, post links responsibly!
Eat the Pudding!
ODE to the N\A
"I have not TURBINE to compress my buttocks, O lord,
Pity will be thine when thoust can crap on with boost.
We of the 'N\A - N\A' knowst nil of the pulling glory,
Yea, to post, thy blight the day of those who pressurise their pipes,
Alas, suck be mine that my chariot breathes,
Strike me down for mine is an unworthy existance"
Old 13-03-07
900t's Avatar
900t 900t is offline
Saabista
I think the handbrake issue is more related to depositing pad on the disc pretty badly in such scenario. After a hard braking you don't even want to stop as the material can "weld" itself to the disc.
