TCS - stupid question probably?? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 02-03-07
Janiap Janiap is offline
My Saabs: Saab 9000 2.3T Aero Auto 1996
Default TCS - stupid question probably??
Hey All
I own a 9K '96 CS Aero Auto. From what I gather it should have TCS as firtly introduced in 1995. Does it? And if it does should the TCS stop the car from wheel spinning on take off or is it just a keep the wheels grounded when cornering? Can anyone expand on this??
Thx
Old 02-03-07
djtaylor djtaylor is offline
My Saabs: 9000 Aero
It's to prevent wheelspin during acceleration. My understanding on these cars is that they modulate the ABS system on the side that's spinning and in the case of both wheels spinning will also cut engine power accordingly.
Someone else may give you a more technical write up. I don't have it so it's not something I get concerned about.
David.
Old 02-03-07
Stuart Stuart is offline
My Saabs: 1996 9000 Aero
I have a 96 model year manual Aero and that doesn't have TCS - I thought it was taken off the later models (not sure which year though)?
Old 02-03-07
Default For those cars who have TCS
Hey guys
For those of you that own a '96 Aero Auto who know they have TCS - is there a switch on the Dash to turn it on/off? Or how can you tell???
Cheers
J
Old 02-03-07
LondonCSE LondonCSE is offline
if you have the switch its next to the cabin temp sensor under the heated seat switch. i guess either way if you don't have that switch when you turn on the ignition you should see the orange TCS light come on for a second or so. i can't remember when they did away with it but search the posts - this has definitely been on here before.
Old 02-03-07
Robinb Robinb is offline
My Saabs: '96 9K Aero auto. Maptun Stage 5+
Posted by Janiap: For those of you that own a '96 Aero Auto who know they have TCS
I thought that TCS on automatic 9000 models was discontinued in 1993.
Old 04-03-07
Totally right Robin - its only on V6 and manual Aeros - thanks for all your help BTW
Cheers
J
Old 04-03-07
John Z Williams's Avatar
John Z Williams John Z Williams is offline
Vendor
My Saabs: b234-E85-10.59@138.57mph
I have a manual 1995 9k aero and it has tcs and it has the off button, which was an option for many of them, kind of expensive, but it does work, I turn the tcs off and I can spin the tires easily. One of the big issues with tcs is if the throttle body goes bad, bad tcs, the only option after attempting to calibrate it, is to buy a brand-new one. Around 800.00 bucks... That is the biggest down-side that I see with the ill fated tcs on 9000's. They did discontinue after 1995 I believe and by 1997, they were all but gone...
I have to say my feelings on tcs have changed some and I think it might help save my 9k tranny! It has been shown on a track with a 9k with tcs, the car turned faster lap times with tcs engaged than it did with it disengaged, and although the car felt faster without tcs with the wheel spin and all that, the actual times were slower
John
