Request: Windshield wiper linkage diagram from WIS - SaabCentral Forums
Old 14th February 2007
MarkJ's Avatar
MarkJ MarkJ is offline
My Saabs: NO MORE SAAB FOR ME
Default Request: Windshield wiper linkage diagram from WIS
My driver's side wiper linkage has broken/disconnected due to being trapped in ice, only the passenger wiper is working.
Could someone please post wiper linkage diagram from WIS? Thank you!
Ambisaab's Avatar
Ambisaab Ambisaab is offline
My Saabs: 03 9-3 Aero BSR Stage 1 & JR Filter
OK... at work at the moment. Will sort it when I get home.
MarkJ's Avatar
Thank you!!
Old 15th February 2007
Ambisaab's Avatar
These are about the best I could find Here and Here. If they aren't good enough let me know and I'll spend a bit more time searching EPC and Wis.
MarkJ's Avatar
Thanks Ambi. I am waiting for the weekend to work on my car in the garage it is way too cold to work on it outside. BTW, How did you get access to WIS?
MarkJ's Avatar
Nevermind, I "found" a copy! Thanks again for your help I appreciate it.
gjdavies's Avatar
gjdavies gjdavies is offline
My Saabs: Saab 9-3CV Aero TTiD 180
Same happened to me.
Plastic joint had failed, so needed new wiper mechanism.
...just give me ten minutes, look at the moon or something...
MarkJ's Avatar
Thanks GJDavies. I just called the local Saab parts department and they told me the same thing. Saab doesn't carry parts for the wiper linkage they just replace the entire assembly including the wiper motor! $280 w/o labor!!
brianl703 brianl703 is offline
My Saabs: 2006 93 2.0T
The MSRP on that part is $260, too.
Saabparts.net has it for $197.
MarkJ's Avatar
Thanks Brian, I appreciate the saabparts.net tip. My local dealer has quite the markup!
MarkJ's Avatar
I fixed my wipers! After getting under the hood I noticed a ball-joint had popped apart in the linkage.
I applied pressure to the two sections with a pair of pliers and it popped back together. My wipers are back in action!
Score: Me 1 , Dealer's Parts Department 0
oh, and wallet +$200
Old 9th December 2009
lxcxs lxcxs is offline
My Saabs: 9 Aero 2.8T
Having the exact same issue,
happened last night there was barely any ice or snow on the car (had just started snowing) and passenger side didn't go on and is loose i can move it by hand.
Could you give me some tips at what you did ? We got a huge storm now and I can't drive without my wipers!
Thanks for any help!
MarkJ's Avatar
I used a huge pair of pliers to force the wiper ball joint back into place. It worked for about a year and then it failed, I had to get the entire linkage replaced. Give it a shot, but you will need to get the repaired. Try to find an indy Saab mechanic to do it for less $$ than the stealership.
2004 9 Aero WAAAAY OOW
Car Modifications:
Koni FSD's, EBC Greenstuff slotted rotors / Akebono EUR pads, Aux-in, Infinity Basslink, Boston Acoustics FX3/4's,
Euro rub strips, hardwired radar, Silvervision PY21W, PIAA LED citylights, Viggen deadpedal, XM
Old 27th November 2011
Tomaseli Tomaseli is offline
My Saabs: Saab 9-3 Aero 2.0T
Hi guys do you know the different of these windshield spindle frames
#12.757.154 and
#12.755.304 , i kow 12755304 comes with a motor but i dont need one , and 12.757.154 looks just like the one i took out of my car. but they say its only for 05-10 and i have 03.
do you think it would fit mine .
'97 Saab SE Turbo's Avatar
'97 Saab SE Turbo '97 Saab SE Turbo is online now
Saabista
My Saabs: Black on black '97 Saab 3-door SE Turbo
According to the EPC, part number 12757154 is for the 06-10 cars. For the 03-05 cars, it shows a separate part for the spindle frame of 12785919 ($271 USD) which is superseded to 12755304 ($283.93 USD) for a LHD car.
So, it looks to me that Saab eliminated the spindle frame and replaced it with the entire assembly for $12.93 more.
You can check the price of the parts on Nick's http://genuinesaab.com/pricing/ web site... Ron
Old 28th November 2011
Well im gonna take the chance and order 12.757.154 only the spindle frame ( 80$ )
i have removed the motor from my fram and it looks the same
Old 22nd April 2012
Last_saab_standing's Avatar
Last_saab_standing Last_saab_standing is offline
My Saabs: 2005 9-3 ss aero
did it fit??
thanks
Live as if your were to die tomorrow. Learn as if you were to live forever.
Old 1st May 2012
Wink
Originally Posted by Last_saab_standing View Post
did it fit??
thanks
Fitted Like a glove
Old 12th June 2013
speedaero speedaero is offline
My Saabs: 06 9-3 aero stage 1 89 900s-sold
Garage
thank god I found this link. I have had the same issue twice in 3 weeks. its a pain and its not even winter anymore. does anyone know if there is a fix to this problem? I can get the arm back on every time but it pops right off under very little pressure.
Old 12th June 2013
Garage
just answered my own question. I found these on ebay not sure how well they will work but it might be worth a try.
http://www.ebay.com/itm/SAAB-9-3-93-...item2ec87789ad
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
