cutting out... - SaabCentral Forums
Old 10-02-07
marmite marmite is offline
My Saabs: Saab 900 Carlsson
Default cutting out...
Recently my car has developed a slight problem. If i have had my foot down in say 3rd gear, and i let off the gas and put in neutral, occasionally the engine will drop to real low revs and cut out. any ideas ? thanks for looking
Old 10-02-07
TheRedBaron's Avatar
TheRedBaron TheRedBaron is offline
My Saabs: 1990 900 turbo
Does it only happen when you let off the gas after being above 2300-2500 or so rpm, and not when you are lower? If so I might suspect the BPV...
The faster you go, the more you see.
Old 10-02-07
only when falling from high revs.. what is the bpv... ?
Old 10-02-07
Turbo Bypass Valve - it releases air pressure from before the throttle plate when it closes (ie when you let off the gas) after being in a boost situation. It's located at the front of the engine on the left (if your looking from the front) side of the flywheel cover, attached to the rubber joint on the intake inlet on the turbo. It is kind of a pain to get to, because you have to spend a few minutes taking off all the turbo piping to get to it. It has a tube that goes over to the throttle body, and a vacuum line to the intake manifold. If you suck on the vacuum line connected to it and find it is not able to hold vacuum, it isn't operating properly - it is both leaking vacuum and not doing its job. About 60 bucks for a new oem one from eeuroparts.
Old 10-02-07
Ah, there could be a problem here. I have an atmospheric dump valve on the car and the pipe running to the inlet manifold is blocked off and also at the turbo end where the standard BOV should be situated. My atmospheric valve is situated on the new front mount intercooler piping...
Old 10-02-07
That should be fine (it should be close to the throttle body, though) position-wise, if it has an adjustable spring I might make it a little looser and see if that helps (while still staying shut under solid boost of course).
Old 10-02-07
i will try the yellow sping in it tomorrow then and see if that helps. They are fairly easy to change as the valve just screws in. It is situated about the same distance away as the standard one. It's on the upward pipe from the FMIC. Thanks for your help
Old 10-02-07
Yeah I don't have one of those adjustable ones, but the almost stalling (and sometimes stalling if your aic is weak) is definitely symptomatic of the valve not opening (when I disconnect mine this is what happens).
Old 10-02-07
Sounds very possible. I will let you know how i get on when i change it tomorrow. Many thanks
Old 10-02-07
Orca Orca is offline
My Saabs: ܁
Is that instead of the green spring, or the blue spring?
If you're using the green spring, then definately change it - it's waaay too soft. I use the blue spring on my T8, with standard APC and 0.35 bar basic boost. I found the yellow one too soft.
Essentially, the valve is not closing quickly enough and the car is over-fuelling.
Old 10-02-07
I am currently using the blue spring and running just over 1 bar of boost.
Old 10-02-07
My Saabs: ܁
Nah ... that's the right spring, IMO. Perhaps try the yellow spring with a couple of washers? Maybe just moderate how you drive and don't drop the clutch for long from top boost
