Lug torque - SaabCentral Forums
Old 26th January 2007
ArcGP ArcGP is offline
My Saabs: 2000 9-3 SE 5 speed
Default Lug torque
Hey everyone,
I am planning on swapping the rims on my 2003 9-3 out for a different set of Saab factory rims. I plan on attempting it myself, but can't seem to find any mention of the proper toque setting for the lugs.
Anyone know where I can find it? Surely there are some DIYers here?
Any help greatly appreciated.
GP
Cojoroh Cojoroh is offline
My Saabs: '04 Saab 9-3 Linear MT
80 foot pounds.
jpk jpk is offline
My Saabs: 2007 2.0T
It seems ridiculously low, but it is 80 ft-lbs. It's buried in the owner's manual somewhere.
I found out the hard way the first time I went to torque the bolts down after rotating the tires. Started torquing down the bolts "by feel" like I've always done, and at what seemed like relatively low torque, one of the bolts snapped. It prompted me to go out and buy a torque wrench.
Thanks guys, I guess I need to read my manual a little closer. I plan on using a Torque wrench, too. Hope it goes well. First time doing it all myself.
fishzine fishzine is offline
My Saabs: 2006 93 SS, 2000 93 Vert, 2001 95 Wagon
Alloy wheels always get torqued much lower than the old steel wheels, also always make sure to re-torqued any wheel after a couple hundred miles as allow wheels are known to have the bolts loosen up after some driving. Had this happen in my last car once and was surprised by the time I felt the shake in the car it had worked itself REALLY lose, but then again that car always drove like crap.
shaggy shaggy is online now
My Saabs: '08 Edna, cosmic blue on parchment
are torque numbers affected if the bolt threads are greased/lubed?
Pokerguy Pokerguy is offline
My Saabs: 2006 9-3 SS Aero
Why would you grease/lube wheel studs ? This is one item that you don't ever want to back itself off . . . and it's not like 80 ft/lbs is very much to worry about getting seized on there.
In short, IMHO don't ever grease wheel studs. Clean them with a wire brush and a rag . . . but no grease or never-seize.
yes, lubricants will give you a different torque reading.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
