Flow rate for stock fuel injectors? - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9-3 SportSedan, Cabrio ('04+), Combi & 9-3X, 2003-2012 > 9-3 Sedan, Convertible ('04+)/Combi & 9-3X Tuning/Modifications - ALL ENGINES
9-3 Sedan, Convertible ('04+)/Combi & 9-3X Tuning/Modifications - ALL ENGINES Covers GENERAL Tuning & all Performance modifications that are *non-engine specific* in nature
Old 23rd January 2007
mbodo's Avatar
mbodo mbodo is offline
My Saabs: 03 9-3SS
Default Flow rate for stock fuel injectors?
Thought this might have been covered, but I'm an idiot when it comes to using the search feature effectively.
Anyone have answers for the following:
Flow rate for the stock fuel injectors
Expected maximum duty cycle (usually less than 80%, not sure what we've got..)
(edit)
Fuel injectors, B207R
Type Siemens, colour green
Style 2 hole
Resistance 12 ohm
Flow capacity ml/30s 176 +/-7
Maximum permitted difference between injectors ml/30s 14
Can anyone verify the maximum duty cycle for the injector?
Static pressure @ fuel rail (fuel pump capability)
Thanks in advance
JonV JonV is offline
Saabista
My Saabs: 03 SE 5 Spd
http://www.rotaryeng.net/injector-table2.txt
Old 24th January 2007
VectorDan's Avatar
VectorDan VectorDan is offline
My Saabs: 2003 9-3SS 2.0t Vector BSR Stage 3
Thanks in advance
Originally Posted by Workshop Information System
The pressure regulator is a diaphragm-controlled overflow valve set for 3.0 bar.
So the pressure in the fuel rail is kept constant at 3.0 bar. Excess fuel is released via the overflow valve back into the fuel tank.
Hope that helps!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
