relays - SaabCentral Forums
Old 4th January 2007
JimmyG's Avatar
JimmyG JimmyG is offline
My Saabs: '85 900 T16S Aero, '80 Black 2Dr 99T
Default relays
my 1988 is missing a few relays, like the ones for upshift indicater.
will any relay that fits that slot work or is there a specific one i need?
900t's Avatar
900t 900t is offline
Saabista
The Shift Up light only came on the US spec cars. So you are missing the relay. Though, you may be able to stick one in, and then it would work if you want it I don't know if the other stuff on the system (switches etc) are present tho.
A lot of the relays are interchangeable, depends which ones though.
JimmyG's Avatar
ugh, i'll leave it then i think its pretty obvious when its time to shift up anyways
Old 5th January 2007
SpecialTool's Avatar
SpecialTool SpecialTool is offline
My Saabs: '88 Aero, '88 vert
Yeah, about as useful as the "fasten seat belts" light.
SteveTheFolkie's Avatar
SteveTheFolkie SteveTheFolkie is offline
My Saabs: 1987 900 8V
I disabled mine (they irritate the heck out of me for some reason) - if I had a turbo I'd use the socket for a knock indicator light - but I've got an NA so it just remains dark ....
philb's Avatar
philb philb is offline
My Saabs: '91 900 T16S on Megasquirt2/Extra
I find that useful, on a RHD drive car the light is closer to the passenger. If they haven't belted up, you can just point at the light. They are always shocked that such an old car has that feature
philjohnhb's Avatar
philjohnhb philjohnhb is offline
My Saabs: Black T16 'Carlsson' vert, 9-3 Aero Vert
'On a RHD car the light is closer to the passenger' Mmmmmmm. Like to think that one through again?
Phil H-B
Originally Posted by Jim Mesthene
Other pieces of your car could fall off, if not bolted on.
kemosaabey kemosaabey is offline
My Saabs: MB 190E ex 9000i 900i 900GLi T16Sx2 99x3
yep, it's a mandatory requirement now on all cars, they all beep incessantly too once you hit 15mph to make sure.... then you have the key in ignition warnings.......highly irritating...
mikewitdaspike's Avatar
mikewitdaspike mikewitdaspike is offline
My Saabs: none, but it's coming again...
god i HATE those! our van and scion have em, and its the most irritating thing in the world (well, actually, that shift up light is pretty bad, lol)... they never turn off is the problem, not till you start the car anyway
900t's Avatar
Saabista
What's interesting is normally none of my "FASTEN BELTS" lamps work, unless you push down on the key, then you get the 8 second spiel.
From '73-75 in the USA, all cars had to be made so that you couldn't start the car unless the seatbelts were fastened. And the car had to see weight on the seat before the belt so you couldn't just buckle them and sit down... later the law was turned back and everyone cut out the devices...
JimmyG's Avatar
the seat belt indicators are a good idea really. but i wish they'd only beep once or twice and then leave it up to the people in the car. we had a new 9-5 with a seatbelt warning, you'd have thought the car was gonna blow if you didn't know it was coming with all these beeps and flashing lights...
900t's Avatar
Saabista
It shouldn't beep if you have the belts clicked in before starting... though of course I always do it after to give the engine a second of idling...
TheRedBaron's Avatar
TheRedBaron TheRedBaron is offline
My Saabs: 1990 900 turbo
Of course the easy solution is to actually buckle your seatbelt...its saved my life before.
I wonder what interesting things could be done with the space where the fasten seat belt light is. Its an interesting shape of hole. maybe a row of small pots that have various functions?
Brainstorm Time!!!!!!
The faster you go, the more you see.
JimmyG's Avatar
no, i meant if you drove with out the seatbelts on
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
