Hi all. Had to pop in for a check see. Nice to see all the familiar faces around!
Yesterday I took the ol boy in for 2 recalls, one of which being the gas cap thing. I had a CEL, but they said the cap wasn't throwing the code. What was? My SAI pump. Sigh. So here's the cursory research I did so far (hard since SC won't let me search for SAI):
Thanks all...Sorry I ain't been round the hood more...
I love the WWW. With the advent of the Rock Paper Scissors Forum, and the
Zombie Preparedness Initiative Forum, I'm ready for whatever life decides to throw at me. |
| Sponsored Links | ||
Advertisement | ||
I think the car will absolutely freak if you just rip it out. Oh, it will run fine, but you'll have to put some electrical tape over the CEL. The SAI is designed into the ECU software for 2003. Its part of the emissions system. There's no getting around that.
John "Where am I going and why am I in this hand basket?" |
I suspect this car runs clean enough without the SAI, and that's why it was deleted in subsequent years.
What does the SAI sensor do? I'll have to look into that. Does it simply measure output pressure from the SAI pump, verifying that the pump is in fact working? If you read the WIS, you will note that the SAI is only used for a short time during a cold start. It is really not needed in most operating conditions. Deleting the pump... AFAIK it is illegal to delete orginal emissions equipment in almost all states. Doesn't matter if the car passes emissions levels without the equipment. The requirement is for the original equipment to be present and operating properly. In New Jersey the CEL cannot be lit for the car to pass inspection, regardless of how the vehicle actually performs in the tests. Assuming it is legal to delete the SAI in Michigan, you probably need to fool the ECM into thinking it is there. That requires knowing more about the SAI sensor. Plugging up the hole in the airbox is easy (SAI inlet). The outlet from the pump goes through a silver check valve that is easy to see on 2003's. It is mounted just to the right of the engine as you face the car. Capping off a tube there would be pretty easy. Look at post #1 in this thread. The check valve is top center. It would be very easy to cap off where that short run of black hose is attached. SAI inlet is lower right, attached to the airbox by a 90 deg fitting. http://www.saabcentral.com/forums/sh...ad.php?t=90122 So how does the SAI sensor work? May not be as easy as I thought if it works like this: http://www.gti-vr6.net/library/engin...injection.html Last edited by ctrlz; 28-12-06 at 02:44 PM. |
Sadly those SAI pumps fill up with water from condensation. Theres gotta be a way to rig the new one so it drains or drill a hole and fit a plug?
Only US diesel?? 03 93 Cosmic Blue Also Black 06 93 Combi, White 89 900TCV |
The SAI pump for my '03 just went bad last week. $800 parts and labor (ugh!). I'm hearing a lot of things about these pumps going bad. Any chance of a technical bulletin for Saab or (god forbid) a recall on these things -- or do these typically only last 60,000 miles?
My SAI pump went bad last month. Covered under warranty.
Lots of water in the thing. The computer program that Saab uses went step-by-step in diagnosing the problem. It turned out to be the SAI. I just learned that the fuel filter in the 9-3 is incorporated into the fuel tank. You have to drop the tank to change the filter! |
If the SAI pump really isn't needed then Saab could issue an update to disable it.
GM did something similar about 15 years ago--apparently they had cars with both MAF (mass air flow) and MAP (manifold absolute pressure) sensors. The MAF sensors had problems so GM issued new firmware (it was on a "MEMCAL" module in those days) that told the computer not to use the MAF sensor anymore and to use the MAP sensor instead. |
I called Saab to see if there has been a recall on this part. It seems that a lot of us owners have had similar problems. I was told that if enough owners call Saab and complain that they have cars with faulty Secondary Air Injection Pumps and Valves that they could issue a recall. If you have replaced the parts and a recall is issued Saab will issue a refund to you. I have filed a formal complaint with Saab on these parts PLEASE do the same. Saab 1-800-955-9007
If your handy with a set of wrenches and a few sockets, the SAI pump can be changed in under 2 hours. The hardest part will be getting the top starter bolt out.
I did mine last summer, and after some exploratory surgery, the culprit to the whole issue is actually the diaphragm inside the SAI pump check valve. The diaphragm is a soft rubber and after a while the heat from the exhaust and it's normal operation causes the rubber to disintegrate and allow hot exhaust gases to cool in the SAI system and condense, thus corroding and rusting out the motor for the SAI pump. |
Based on dealer paper I got on my 03 when I purchased it used, says dealer "replaced SAI return valve and gasket" (I assume that the silver SAI valve itself). This was done in June 08. I may put a new one one in 2 yrs or so if car is still going strong. |
Is there a way to take the harness off the old seized pump and maybe put a resistor or capacitor in the harness to fool the ECU? My light just came on and I am not paying for some crap emissions pump.
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
