Sludge accumalator oil pan - SaabCentral Forums
Old 29th November 2006
Aeronaut's Avatar
Aeronaut Aeronaut is offline
My Saabs: 2000 9-5 Aero, 2006 9-5 2.3T
Default Sludge accumalator oil pan
Saw this on another saab site in the classifieds and thought it looked like a good idea. has anyone had one of these installed?
Sludge/Debris Accumulator Oil Pan (Pat. Pending) (Posted 11/28/06)
Does your oil pan look like this? Oil pressure drops and excessive engine wear begins when carbon or foreign particles clog the oil pick-up screen. The conventional oil pan and pick-up screen must be removed and cleaned to restore proper oil pressure and prevent engine failure. In some extreme cases an engine flush is required to remove the sludge. Even after an engine flush is completed, contaminates continue to be washed from the engine walls by oil flow into the oil pick-up screen requiring another costly and time-consuming oil pan removal. Remove Sludge; Not the Oil Pan. Install the Sludge/Debris Accumulator Oil Pan and in minutes during regular oil changes, the accumulator cover can be removed, and the oil pan and pick-up screen can be inspected. Cleaning of the oil pan and oil pick-up screen is done by placing a Shop-Vac hose against the oil-pick screen. Oil remaining in the engine is pulled through the pick-up screen washing away particles and sludge leaving a cleaner environment in which to install new oil. The Sludge/Debris Accumulator Oil Pan gives you peace-of-mind that your engine is not suffering from oil starvation caused by sludge build-up. The Sludge/Debris Accumulator - Engine Sludge Insurance. Contact your local Saab specialist for information and installation or contact ABC Sales.
Contact:
xxx xxxxx , Sweetwater TN
Email:
Old 30th November 2006
NateWI's Avatar
NateWI NateWI is offline
My Saabs: 2004 9-5 Aero Sdn 5sp
Not me personally, but Chuch Andrews (Andrews of Princeton) has been using one for a while as well as doing other sludge tests and monitors. If you're not familiar with his work, check out his website andrewsofprinceton.com and look for his NINES articles. Most recent article has a photo or two I believe. They also have a method for cleaning engines and a maintenance plan for eliminating sludge.
If I were closer and needed another late model Saab, it'd surely consider buying from him. They are definitly looking out for you best interests as well as your Saab's
Nate
MacNoob's Avatar
MacNoob MacNoob is offline
My Saabs: 01 9-5 Wagon (RIP); 05 9-5 Aero (gone)
Have you ever been to Andrews? It's Saab heaven. Picked up my sport chassis kit from them this summer and had them do some other minor work - it's about a 7hour drive for me.
Huge shop (must have about 24 service bays), lineup of a couple dozen used Saabs, lineup of a few dozen wrecked-for-Parts Saabs, and friendly knowledgable people. I was so tempted by the steel grey '02 Aero wagon on the lot....
bkrell's Avatar
bkrell bkrell is offline
My Saabs: gone: '01 9-5 2.3t, 1997 900 SE turbo
I spoke with someone a week or so back who had one and he said they weren't very expensive. He didn't say exactly how much...but he said labor would be much more than the price of the pan.
I cleaned my pan back in the spring, so, hopefully between that and the update #6 I just ordered about 5 mins ago I'll be okay. I went ahead and got the kit b/c I stripped my bleepin' drain plug last night and need a new one.
Old 12th January 2007
nc73 nc73 is offline
My Saabs: 00 Viggen
thought I'd bring this back. has anyone tried it?? It's $350 and they emailed me the pdf with the specs. looks like it is good insurance.
Josdek's Avatar
Josdek Josdek is offline
My Saabs: 2003 9-5 2.3 Auto B234 block E85Biopower
Default $350??
That seems a little steep...couldn't one just fabricate an access hatch, secured by bolts and a seal, a lot cheaper? Cut a hole in the pan, get a circular piece of aluminum ("al-u-nin-ium" in the UK!) and drill press the holes....
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Sorry................tried what?
Oh that thing...............erm why?
Drop the pan (s u m p) in the UK, clean it then only use fully synthetic oil changing it every 5,000 miles (plus make sure the PCV is good and up to date).
Problem solved?????
My Saabs: 00 Viggen
yeah but the one they have is much nicer. I don't have a welder either.. It would be nice to be able to check it once in a while to see what's up. Sure I can drop it once, clean it and forget about it..but it would just keep buggin me. Also because you did it once it doesn't mean it won't come back.
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Yes it does..........well unless you dont change the oil regularly, or use crap oil or have a duff PVC or all three
My Saabs: 00 Viggen
I doubt that. As for the PVC, there's been so many updates who knows which one actually works. Wasn't there a post where someone checked 7k miles later and there was more crud found? I don't think there is a definite fix for sludge. With the access hole, you can check it whenever just to be sure. I plan on keeping the car as long as I can.
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Ok its your money...........what do I know
i want an aero's Avatar
i want an aero i want an aero is offline
My Saabs: 1998 95 2.3 lpt se nordic tuning
far less than you think juding by this narrow minded post
Old 15th January 2007
My Saabs: 00 Viggen
Correction 250 is the final price. 350 is with a 100 core charge.
Old 13th June 2016
capang9555 capang9555 is offline
My Saabs: 1999 Saab 9-3 Convertible
Anyone know if they are still in business? Their site is no longer in existence.
Old 13th June 2016
andybisnut andybisnut is offline
My Saabs: 2006 9-5 SportCombi 2.3T
Garage
Sadly no. The owner is retiring and they've closed up shop.
They were auctioning off all their assets though, which may be worth a look for anyone in or near MN. Not sure if the auctions are still going on.
Old 15th June 2016
Old 15th June 2016
Jssaab Jssaab is offline
My Saabs: 2000 9-5 Parts, 2003 Aero Hirsch "Clone"
You shouldn't need it if your car is well taken care of ( synthetic oil changes every 5K or better) and you have the PCV upgrade
Old 15th June 2016
Car has updated pcv kit and previous owners took it in every 3k miles. But they didn't use synthetic oil. I have full service history. But I had the pan dropped anyway last week and the pickup screen was pretty clogged up. Had it cleaned. So I hope I won't have to deal with dropping it again.
Old 15th June 2016
Gen-X'er's Avatar
Gen-X'er Gen-X'er is offline
My Saabs: 2000 9-5 2.3t
Garage
Supposedly, doing all of those things virtually eliminates the issue. Here's hoping the internet is telling the truth. I've never heard of the internet being wrong before.
2000 9-5 2.3t
Old 16th June 2016
Mike Brennan's Avatar
Mike Brennan Mike Brennan is offline
My Saabs: (4) 2 01 95's; an 08 95 & a 09 93
This issue was very active before the 2005 with engines failing all over the place. Saab replaced hundreds and this guy sold a lot of these sumps on the recommendation of Chuck Andrews. After the PCV Mod 6 came out the remedy of sump drop and synthetic oil pretty much eliminated failing motors except for those who never heard of the issue. That is why it is still risky to buy a pre 04 without records. I bought a an 01 from Andrews with a replaced motor
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
