| Saab 9-5 Workshop Saab 9-5 Workshop (1997 to 2010) Technical Forum |
My left front tire is wearing on the outside of the tire, but it's uniform around the whole tire. The rest of the tires are just fine. My allignment seems ok, and I've also checked the pressure and it's good too. Any ideas of what could be causing it or do you think that it could be my driving style? There are a couple of hard right turns that I make to and from work.
| Sponsored Links | ||
Advertisement | ||
What load index are your tires?
I found my left front tyre wear's out the quickest as well, which is why I now try and rotate them around as much as possible to even out the wear.
I always assumed it was because we have roundabouts here in the UK, which of course you don't have in the US.
Blessed is the sound of a ninety-two on nitro...... |
Massachusetts has quite a few. We just call them a rotary. |
Theres a tyre fitters in Leighton Buzzard (confusingly) called MK Tyres that knows when anyones come down from Milton Keynes because of the tyre wear pattern i.e outside edges of the front tyres worn. As mine are at the moment, pair of Falkens on the front fitted last year , probably less than 10,000 miles and sh*gged.
Milton Keynes has probably more roundabouts than any where I know of. Last edited by bazwold; 22-11-06 at 08:04 AM. Reason: Forgot the point of my post |
Michelin Energy MXV4 215/55R16 V Speed Rated I was going to rotate them, but the wear on that one tire went so quick from the last rotation that now it's not even worth it. And we do have a few roundabouts here too and but we call them traffic circles. It's about time for new tires anyway, but I just wanted to see if there are other causes that I need to look out for. I'm pretty sure it's my driving style tho especially after reading other threads and seeing the same type of wear described. Maybe I'll run a bit more air pressure than normal to help with the loading.... |
Tyre sizes are made up of a number of different numbers and letters. For example tyre size 185/60 R 14 82 H is made up of the following information:
185 The tyre section width in millimetres 60 The aspect ratio in % (the height of the sidewall divided by the tyre's width) R Denotes the tyre's construction type - in this case it's a radial 14 Rim diameter in inches 82 Load Index H Speed Rating The reason i ask is because SAAB changed the load index from 91 to 94XL (extra load) following complaints of excessive wear on the outside of the tyres. If you are running 91's this may partially explain why they are wearing in this manner. Last edited by Kermit; 22-11-06 at 02:49 PM. |
Thanks Kermit,
I'm still not sure what the load index is on my particular tire I can't find it online and I'm not about to go look at my tires in the weather we are having. However, I do know that those tires were the OEM tires put on that year ('99) in the states. I guess the last owner just kept with them for ease in tire buying. So, if those were OEM and Saab increased the load index from 91 to 94 I'd say that those tires aren't cutting it and that explains a lot of the wear. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
