Lumpy idle - SaabCentral Forums
Old 19-11-06
developer215 developer215 is offline
My Saabs: 9-5 Estate 2.0 Auto 2002MY
Default Lumpy idle
Hello again,
Any views on a lumpy idle that you can feel as a vibe thru the seat?
I recently had to replace the DI unit as my engine malfunction light came on and my specialist told me that the idle would get better with a new DI unit but to be honest it's still not very smooth for an expensive sophisticated car.The rev needle is rock solid but the idle feels rough. Other 4 cylinder cars of a lesser pedigree (for example Peugeot 406 and various Rover's) have been better than this.
Any ideas?
John
Old 19-11-06
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
You might get a better response to your questions if you posted them in the workshop rather than the performance section.
Old 19-11-06
Kermit's Avatar
Kermit Kermit is offline
Saabista
My Saabs: Citroen C5 2.2HDi
John, this vibration problem seems to affect some auto's but not others. We've never got to the bottom of why its like this either. I've noticed mine is worse after an oil change/service but smooths out over the next few months... The next thing on my list to be changed is the torque rod between engine and gearbox, hopefully this might work but i'm not gonna hold my breath.
Old 19-11-06
Default Lumpy idle
Thanks guys - reposted. Sorry for the duplicity on the system.
Old 19-11-06
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
When I changed the CPS to cure stalling it also smoothed the idle too
Old 19-11-06
What's the CPS?
I also notice that the engine struggles like buggery and produces a knock knock knock when at idle with the steering wheel on full lock - when pulling out for example.
Should have said, it's done 77K
Old 19-11-06
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Crankshaft Position Sensor - try a search
PS...... all these 9-5's struggle at low speed on full lock, infact you should always back off a couple of inches off full lock due to the extreme pressure within the power steering system.
