Saab 95 2.3t auto - engine cut out - SaabCentral Forums
Old 5th November 2006
stephensykes stephensykes is offline
New Member
My Saabs: Saab 95 2.3t auto
Unhappy Saab 95 2.3t auto - engine cut out
Hi,
Can anyone help me to understand the problem I have with my 2003 Saab 95 2.3t auto. It simply cut out when on the motorway last night. I had to pull into the hard shoulder and get a tow. The engine rotates but no ignitiion at all. I checked all the fuses associated with engine management and they're fine. I don't want to get Saab involved unless I have to so if anyone's got a clue I'd appreciate it
Thanks
twilker twilker is offline
My Saabs: 2003 9-5 Linear Wagon
Most likely your Direct Ignition Cartridge (DIC) has gone bad. This provides the power to the spark plugs. May also be the Crankshaft Position Sensor (CPS) when provides information to computer when to fire the spark.
The DIC is ~$190/US and CPS ~ $40/US and both available from eeuroparts. There are many many threads on these two subjects since they tend to fail quite often on these cars. Search these forums for more info.
It always helps if you can get it diagnosed since throwing money at possible problems can get expensive if you don't get lucky.
Gazolzwurf Gazolzwurf is offline
My Saabs: 9-5 Aero MY05 / 9-5 Aero MY02
^ Stephen, what twilker says ^
Click search, click advanced and search on any or all of these words
Direct Ignition Cassette
You'll find lots of info.
Pictures of the part on this thread
And welcome to SC
skibum_infdl's Avatar
skibum_infdl skibum_infdl is offline
My Saabs: '85 SPG, '10 9-5 Aero
You could have an independent service bring up the fault the code. Then pull the #17 ECU fuse. If it isn't the DIC, your car's ECU is probably in limp home mode. Pulling the fuse for 15 seconds or so will reset the computer. I'm guessing you have a bad throttle body sensor. If you want to try just pulling the fuse, go ahead. Worst case, it doesn't work and the code shows up again. Then you can pay the money to have the code read.
Old 6th November 2006
lights-out lights-out is offline
New Member
My Saabs: 9-5 estate
fuel pump mate
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
