Stereo Question - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 03-11-06
v.razr.x's Avatar
v.razr.x v.razr.x is offline
My Saabs: 93 9000 Aero
Default Stereo Question
Alright...I'm about to change out the OEM Clarion head unit w/ EQ for an aftermarket one.
Besides the wiring harness, is there anything else I need? Like removing the stock amp or bypassing it? Or with the harness, just plug and play?
Thanks in advance!
Old 03-11-06
Marcs_Saab Marcs_Saab is offline
My Saabs: 93 Saab 9000 CSE & 97 Saab 9000 CSE
Lightbulb 93 Saab change
I have a 93 9K CSE and just did this last night (or started.) Your front wires will run off a Crutchfield (or whoever) wire harness but you will need to run wire from the head unit down under the passenger seat to connect the rear speakers and bypass the amp. I am putting my own 100W amp in there and just running RCA down under the seat and hooking the rear speakers to the amp. I can send the wire colors = what speaker list if you need it.
Let me know.
Old 03-11-06
v.razr.x's Avatar
That would be great!
v.razr.x@gmail.com
Thanks!
Old 04-11-06
prionailurus prionailurus is offline
My Saabs: '98 9K CS T Auto (for sale)
Have a quick look at
http://www.saabcentral.com/forums/sh...ad.php?t=84263 at the links on it, also http://www.saabcentral.com/forums/sh...ad.php?t=83519 could help a little.
Old 04-11-06
This should be accurate.
FUNCTIONPINWIRE COLORAccessory 12 Volt4RDConstant 12 Volt1GYChassis Ground7BKPower Antenna8GNRemote Illumination Dimmer10BN/WTFUSE VALUEFUSE LABELFUSEBOX LOCATION15 AMP#27BEHIND GLOVE BOX15 AMP#19BEHIND GLOVE BOXThe connectors shown are plugged into a jumper harness that then connects to the factory radio. The jumper harness is about a foot long, simply unplug the jumper harness and set it aside. *Without rear channel amplifier. If the factory radio has a round 6-pin DIN connector plugged into it, there is an rear channel amplifier in the system. The rear speaker wires will be found at the amplifier (located under the passenger seat) and must be bypassed if an aftermarket receiver is installed. Since there is no bypass connector available, new speaker wires must be run to the amp location and spliced to the speaker output.
Left Front Spkr +13BNLeft Front Spkr -14GNRight Front Spkr +12RDRight Front Spkr -11BULeft Rear Spkr +19*BN/WTLeft Rear Spkr -20*GN/WTRight Rear Spkr +18*RD/WTRight Rear Spkr -17*BU/WT
Back to top
Rear Amplifier Wiring & Info
123456
Read numbers from pin side of vehicle connector. FUNCTIONPINWIRE COLORChassis Ground1BKLeft Rear - Output2GN/WTRight Rear - Output3BU/WTLeft Rear + Output4BN/WTRight Rear + Output5RD/WTConstant 12 Volt6RD & GY**RD and GY wires both connect to Constant 12 Volt.
The amplifier receives all signal input and remote leads through the DIN cable from the factory radio.
