V6 upper engine mount - SaabCentral Forums
Old 02-10-06
t_buck09 t_buck09 is offline
My Saabs: 1994 Saab 900SE
Default V6 upper engine mount
ok here it is after some well thought out well thoughts, i came up with a good way to produce an upper engine mount for the V6. first things first. i need to know what something is. in the picture below, i need to know what something is, i know its a 4cyl, but its there on the v6. on the sway bar there is a warning sticker on the right side, underneath that there is a *resavor* with a yellow cap, and a black disk shaped plastick hunk there, what is that, and what is the tube running out of that and into the intake manafold????
NEXT!!!
ok now my plan is to get a damper and mount it to the sway bar with a bracker, and connect it to a bolt that runs to the intake manafold, the bolt is roughly 4 in long, i would get a slightly longer and much stronger one., that would complete that process. the reason i ask about the resavoir and crap is because the hose that runs to the manafold would be in the way, unless i found a way to drop the clamp from the sway bar and still make it extremly sturdy... so what do u guys think. i still need to puchase the damper and all the componets, im broke now so it will probably be awhile before any progress, but i just wanted input. thanks much
1994 Saab 900 2.5L V6
-GenuineSaab Rear ARB 25.5mm
-clear indicators
-shift knob, pedals
-custom cold air intake
-mesh grille
-speakers
-stereo
-Thrush turbo muffler
-painted strut bar
UPCOMING
-St2 or viggen bodykit
-ultra light fly wheel
-ecu tune
-3.0 cams
-upgrade fuel system
Any thing else to make this the best saab around
Old 02-10-06
hunt.dogshome's Avatar
hunt.dogshome hunt.dogshome is offline
My Saabs: Clanky 9-3 diesel.
What's the brake master cylinder and vacuum servo? I'm all worried now!
You need those bits mate - and the pipe to the inlet manifold
I don't have a V6 so can't comment about the bolt you've chosen to fix your damper to. It needs to be STRONGO! The dampers arn't what you think i.e. oil filled damper that's soft and moves a lot. They're full of hard rubber and only move 1" max. They take some hammer when you change gear.
[Mind you, with the limited power of a V6, probably not a problem, eh Raggy? if you are watching ]
肉(rņu)包(bāo)子(zi)打(dǎ)狗(gǒu) (meat+bun(2nd and 3rd)+hit+dog)
* Literally: To hit a dog with a meat-bun.:-O
Old 02-10-06
ragtopcav's Avatar
ragtopcav ragtopcav is offline
My Saabs: '98 900 vert, 9000 2.3 stg3, 9-5 waggon
The parts you wish to identify are the brake fluid reservoir and brake booster.
The V6 has a torque damper built in on the 9000, the 900 has all the drillings for this but not utilised, they're within the serp' belt.
Have a look at this shot below of a 9000 V6, note 3 holes in the timing cover, these are the mounting points for the torque damper...
1998 Saab 900se 2.0 Turbo Convertible
1999 Saab 9-5 se Waggon 2.0 Abbot Racing ecu
1997 Saab 9000 cse 2.3 stg 3 (mothballed )
1997 Fiat Punto 1.25 85hp
Old 02-10-06
thankz but i wasnt planning on removing those hoses or nething, i was just wondering, i will have to drop an L shaped bracket from the bracket on the swaybar, to have clearance, also like i said i would get a stronger and slightly longer bolt, so it can thread into the manfold farther for maxamum hold. for those with v6's post a pic and highlight the bolt i am talking about if you know... its on the top of the piece of plastick to the right. thankz much
-clear indicators
-shift knob, pedals
-mesh grille
-speakers
-stereo
-painted strut bar
UPCOMING
-ecu tune
-3.0 cams
Old 02-10-06
ragtopcav's Avatar
Coming to play on the track? It's for a good cause trackday link.
Old 02-10-06
OK understood. I thought you wanted to remove something!
The strut bar is just a tube so isn't ideal to fix to - hollow. There is a very strong part of the frame down below the strut towers. If you can go down and forwards, rather than back and up without hitting anything, that should be good. That's where mine (4 cyl) goes.
Old 02-10-06
A rise! AND a BITE!
Been asked to go to Isle of Man for a thrash, but my other half (gearbox no3) won't let me!
Maybe........
Old 02-10-06
Spectating is a go-er. I need my car on Wednesday, so can't afford to splodge ANOTHER gearbox.
Where's me 'oliday form?......
EDIT:- Regarding holiday forms at work:- Are they accepting dodgy blue Scoobies on this track day? (eh? Big E? Yours only does 14 miles a year, another 5 miles won't kill it?).
Old 03-10-06
Tboy's Avatar
Tboy Tboy is offline
My Saabs: 94 900SE V6
Hmmm, I don't remeber seeing these holes when I had the engine out. The timing cover is only drilled on a 9000 for the engine moun t yes?
From the location of those drillings shown, are two in the head, and one in the block, or all three in the head?
Interesting, I've been contemplating an upper mount myself.
Tboy
1994 NG900 V6 > catalog kit done!
1999 9-5 2.3LPT > soon to be FPT
Old 04-10-06
ragtopcav's Avatar
Tboy
The 2.5 cover has the marks on it where the holes should be [change pieces in the injection moulding die I presume, 2 parts from 1 mould] they correspond directly with the threaded holes that are on the timing pulley mounting plate; as I see it, this is the only safe place on the V6 to apply such a torque control load as it was designed to accept it. Sadly there's no where near enough room to squeeze in the torque arm as fitted to a 9000
Old 04-10-06
Tboy's Avatar
Now that you mention that I do remember those three marks! Hmm, I will take a look at that tonight.
Tboy
