Installation of Roof Mount Antenna Questions. - SaabCentral Forums
Go Back   SaabCentral Forums > Saab NG900, 1994-1998 and OG9-3, 1999-2002 & '03 Convertible (NG=new gen/OG=old gen) > NG900 & OG9-3 Performance, Mods & Tuning
NG900 & OG9-3 Performance, Mods & Tuning Covers Tuning & Performance modifications for the NG900 (1994 to 1998) & OG9-3 (1999-2002) & '03 Convertible
Old 28th September 2006
liketheword liketheword is offline
My Saabs: 2002 9-3SE
Default Installation of Roof Mount Antenna Questions.
Who has converted from motorized antenna to roof mount ala Viggen? Any tips or tricks? I have a 2k2 SE w/ Onstar (not used). Can I just put the roof mount antenna in place of that? Is there any way to rig them booth up?
Thanks in advance guys.
Troll_speed's Avatar
Troll_speed Troll_speed is offline
My Saabs: Saab
Or get a window mounted one and get the hole filled
Am in process of doing this, just need some bodyshop time now
Chris
Old 29th September 2006
I don't want a window mount... The idea of "shark fin" + Viggen antenna doesn't suit my taste...
Any more input guys?
mike saunders's Avatar
mike saunders mike saunders is offline
Saabista
My Saabs: Tuned NG900, stock 99 9-5
Cedric at Saablink has a great tutorial on the site that I used to do mine....
Just be sure to get the blanking plug from GS....
Quattro's Avatar
Quattro Quattro is offline
i've installed the viggen antenna on my roof, bought the kit from genuinesaab including the plug. the install is very straight forward. remove the existing power antenna, plug the hole with the GS cap, pop off the light on the headliner (i drilled directly above it), tuck the wiring through the headliner, under the plastic pillar moulding leading to the trunk, and ofcourse behind the trunk liner where it meets the antenna cable.
some advise...the hole does not have to be large at all, just enough to get the antenna flush with the body. also, once you've done a mockup and lined up the antenna, tape off the surrounding area of the drill location once you've identified it - you don't want your paint damaged by a wandering drill bit..
93 9000CS, 97 900SE
97 900SE Talladega
- Nordic Stg 3,Intrax/Bilstein suspension, JK 3" downpipe w/ gutted cat,cross drilled/EBC Greenstuff brakes, SS brake lines, hydraulic clutch conversion, Spec2 clutch/Viggen PP, Sway Bar, MP IC, Saab Sports Exhaust, MP Short Shifter, 17" BBS RKs, and more...
Cardomain:
My Saabs: Saab
I don't have ANY visible antenna, Viggen or 'Shark fin'....
Chris
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
