Update!!!! 900/9-3 Oil Specs and Issues - SaabCentral Forums
Old 23rd September 2006
bkrell's Avatar
bkrell bkrell is offline
My Saabs: gone: '01 9-5 2.3t, 1997 900 SE turbo
Default Update!!!! 900/9-3 Oil Specs and Issues
I figured I'd sticky this since I've posted it several times. Here's a list of motor oils that are either ACEA A3 certified (Saab's requirement for 2000-2002 9-3's and 9-5's plus the Viggen) or are otherwise known to be stout enough to handle the harsh environs in the potentially sludge prone B205/B235 engines. This list is based on US oils. If you are outside the US and have a T7 car, look for the ACEA A3 spec on the back of the oil container.
Brian's Recommended Oils for T7 SAABs
AMSOIL Euro Formula 5W40
Shell Rotella T Synth 5W40
Valvoline Maxlife Synthetic 10W30
Valvoline Synpower 5W40
Valvoline Synpower 20W50
Castrol Syntec 0W30 (only available at Autozone)
Castrol Syntec 5W40
Castrol Syntec 10W40
Castrol Syntec 5W50
LubroMoly VollSynthese 5W40
Mobil1 0W40
Mobil1 15W50 EP
Mobil1 High Mileage 10W40
Mobil1 TurboDiesel 5W40
Mobil Delvac1 5W40 (mainly at truckstops)
Pennzoil Platinum Euro Formula 5W40 (hard to find)
Redline 5W30
Redline 5W40
Redline 10W30
Redline 10W40
For the Canadians, per ParaMedic_Saab's request, I'll addd
Esso XD-3. That's an 0W40, IIRC. Very highly thought of north of the border.
If you notice, there are not a LOT of 30 weights on this list. 30 weights have a hard time meeting the A3 standard that Saab prefers you use b/c most of them are formulated on the thin side of the 30 weight range (I've learned). Most US 30 weights are on the low side of the range for fuel economy concerns.
As for the NG900, I'd recommend a synth as well. Even the 2.3 n/a can have oil issues if not properly maintained though the overall frequency appears to be lower than the later cars. However, I don't think you'd need to seek out a synth that meets the A3 spec on these cars. That opens up a larger variety of oils in the 30-40 weight range. Oils such as Mobil1 5 and 10W30, the other grades of Castrol Syntec, Quakerstate Synths, Pennzoil Platinum 5W30, etc.
As for capacities...
2.0 and 2.3l engines: 4.2 qts or 4 liters
2.5l V6 engine: 4.8 qts or 4.8 liters
Old 27th December 2006
bkrell's Avatar
Exclamation
FWIW, in the latest issue of Nines, Chuck Andrews (Andrews of Princeton) has related in his ongoing series on the 9-5/9-3 engine failures that he has yet to test a 9-3/9-5 keeping adequate oil pressure with a 30 weight synth oil. Now, I don't know if he's tested the thicker 30 weights such as Castrol Syntec 0W30 (German Castrol), Redline 5W30, or Valvoline Maxlife Synthetic 10W30, but I'd think twice about using any of the thinner ones...a la Mobil1.... It appears Chuck has discovered that even new from the supplier replacement oil pumps for the T7 cars don't remedy the situation.
Old 2nd May 2007
NahumCC's Avatar
NahumCC NahumCC is offline
My Saabs: 1999 9-3 SE, 2006 9-3 Aero Sport Combi
For owners of the ng900 and 99 9-3 as has been posted in the performance board Mobil 1 synthetic 10w-30 does not hold up to saabs oil pressure specs. At operating temp and 2000 rpm I only had 30 psi when I should have 40.
So it is best to stay away from most 10w-30's for b204/b234 motors as well.
1999 Stage 3 9-3 SE for sale
2013 FR-S
Old 3rd May 2007
bkrell's Avatar
For now, I'm leaving Valvoline Maxlife Syth 10W30, Castrol Syntec 0W30, and Redline 5W30 in. They are on the high end of 30 weight and I'd like to see them tested in a car before I de-list them over pressure concerns. FWIW, Mobil1 5W30 is also a tad thicker these days.
The Castrol Syntec 0W30 (the famed German Castrol) may be hard to come by soon in the US anyway, as Autozone appears to have stopped selling it.
Old 3rd May 2007
KLowD9x KLowD9x is offline
My Saabs: 1996 900S
FWIW
Motul 8100 Eco-energy 5w30 makes my lifters tick on a hot engine. (Most like also due to low oil pressure, not to mention probably bad lifters.)
I have since switched back to Mobil 1 0w40. No more lifter noise (except for in the morning).
Manufacturer: SAAB Automobile AB
Product line: SAAB 900 2nd generation or 9-3
Body type: 5-door Hatchback
Gear box: 5-Speed Manual
Engine type: B234 - 2.3L 16V, 150 hp
Model year: 1996
Assembly plant: Trollhattan, Sweden, line B
SRS: w/Dual Airbags, 9-3
Old 3rd May 2007
Saabohème's Avatar
Saabohème Saabohème is offline
My Saabs: 2008 9-3 SS 2.0 6Spd JZW Stage 1
You can add LubroMoly Voll Synthese 5W40 to the list, now available through NAPA.
Old 3rd May 2007
My Saabs: 1996 900S
I can't find ANY data on the stuff but it looks like alot of places sell it, especially ones that specialize in VW/AUDI stuff. Got any spec sheets?
Model year: 1996
Old 3rd May 2007
bkrell's Avatar
LubroMoly VollSynthese has a good reputation. I've seen isolated cases of people complaining about varnish, but you can never take anecdotal evidence for that much....
Old 22nd May 2007
Sued1 Sued1 is offline
My Saabs: 2002 9-3
I have put Royal Purple 10W30 for the last 2 oil changes & before that Mobil 1 10W40 on my 2002 9-3 SE with 110,000 miles. What should I be using for hot climate (Florida)?
Old 22nd May 2007
NahumCC's Avatar
Check your manual first. My 99 9-3 with b204 says for temps above 60 consistently to use 15w-50 or 20w-50. I'm running 10w-40 right now and when its fully warm with temps of the low 90's here in southern indiana its getting down to what 10w-30 ran when it was in the 60-70 temp range.
This was after only a 5 minute drive with outside temps in the 92 region. Car had been sitting for only 2.5 hours while i was at training for my new job but prior to that was fully hot. With another 10 minutes of driving, even regular easy driving, idle woulda been down to 12-14 psi region.
2013 FR-S
Old 23rd May 2007
bkrell's Avatar
I agree with Nahum. In Florida, I'd be running something like M1 15W50 (NOT M1 15W50 Extended Protection), Castrol Syntec 5W50, or Maybe Valvoline Synpower 20W50. That isn't a blanket statement for ALL cars. There are plenty of folks running 0W20 in Miami in the summer with NO problems. But for our cars.....
Old 23rd May 2007
ParaMedic_Saab ParaMedic_Saab is offline
My Saabs: 2001 Saab 9-3 SE / 1972 MGB
BK, need to add some Esso XD3 up on your list for us Canadian saabers
Old 25th May 2007
bkrell's Avatar
Done! How's that?
If anyone has any other oil they see that deserves consideration, let me know.
Old 26th May 2007
Thanks dude and yes there is a 0w30 and 0w40. I use the 30 in the winter, as its closer to a 40, and the 40 int he summer as its closer to a 50
Old 16th July 2007
NahumCC's Avatar
Ok to add to the list here.
Valvoline SynPower 20w-50
Valvoline SynPower 5w-40
Both meet ACEA A3. Here is a link to the list of the SynPower oils (the two above are the only ones that meet it) that gives a good list of specific info about them.
http://www.valvoline.com/products/Synpower.pdf
2013 FR-S
Old 16th July 2007
bkrell's Avatar
Will do! Synpower (Valvoline synth, at least) was the first synth I ever used in a car-10W40 in my old 320i.
Old 16th July 2007
Saabohème's Avatar
Mr. Krell:
I still do not see LubroMoly Voll Synthese 5W40 on the actual list.
Old 16th July 2007
bkrell's Avatar
D'oh! On its way. And as a side note, I don't believe the M1 10W40 HM has the A3 spec, but I'd be willing to bet it's a fine oil. ExxonMobil makes some serious claims about it being able to clean up deposits in high miles engines. I'd love to see someone out there put it to the test.
Old 29th July 2007
NahumCC's Avatar
Your right that the HM M1 10w-40 isn't A3 spec. Also in a bit of a quandry as I recently said somewhere that the M1 15w-50 synthetic had the A3 spec and while looking for 5qt containers found them at walmart without the A3 spec and it was the same with the individual quarts. So i'm gonna run back to the place I bought my 15w50 M1 that had the A3 spec on the back of the bottle and make sure there aren't two different version.
2013 FR-S
Old 29th July 2007
bkrell's Avatar
M1 redesigned this oil to be used in hi-po apps. I doubt they cared if it was A3 b/c that's a Euro spec....just like their HM and diesel oils are capable of meeting the spec. FWIW, the 0W40 meets it and look at how it sheers down. It's a virgin oil spec and while a good indicator, can't promise performance.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
