9-3 Mods - SaabCentral Forums
Old 01-09-06
dre2453w's Avatar
dre2453w dre2453w is offline
My Saabs: 2000 saab 9-3
Default 9-3 Mods
I have a 2000 9-3, auto trans. I'm wondering what people recommend as beginning mods. I have a k&n filter and have done a few cooling mods, just DIY stuff. But what mods do you all think I should do. Just performance and suspension.
Cant wait to hear your suggestions.
Old 01-09-06
byastremski's Avatar
byastremski byastremski is offline
My Saabs: 01 Viggen e85 tuned... 378whp ~ 400lbtq
begining mods... hmmmm...
usually the first mods are
22mm rear sway bar- improves your feel and ability to maintain a higher speed through corners
steering rac and clamp- will help to eliminate torque steer
smbc- since you have a t-7 this will be used to increase your stock boost in turn giving you more hp from your turbo
finally modifying your airbox- this involves some minor DIY... you must cut a bigger whole into your stock airbox and fit a 3" piece of pvc... which will allow increased flow
this will get you a good power hungry start and these are also the mods you can do for the cheapest that will show the most improvement
your next mod after these should be a 3" downpipe... this will increase spool up time... turbo noise... and give you about 10-12 more hp
good luck and hope this helps you out....
Old 01-09-06
SPATL's Avatar
SPATL SPATL is offline
Just some clarification on the previous post. A SMBC is not used to raise peak boost as the t-7 will not tolerate it. It will provide better spool up of the turbo and a bit more boost in the lower gears without raising peak boost in the car. It is a nice option to get you going.
The T-7 also has a different airbox than the t-5's and the snorkel is larger so the 3" duct mod does not apply here either.
The 22mm rear sway bar is a must. Start there.
A steering rack brace is also another beginning mod.
Larger IC and a 3" downpipe are typically the next things to tackle as you prepare your car for a performance ECU.
This is a place to start.
Old 01-09-06
thanx spatl... i did not know the specifics about an smbc... if i get bored at some point i'd like to make a sticky beginning mods... and then have you review because these questions come up all the time... and i think it'd save people a lot of typing to just sticky something like this...
Old 02-09-06
stevehayes01's Avatar
stevehayes01 stevehayes01 is offline
My Saabs: 2000 9-3 SE HOT Automagic
I run a 2000 9-3 SE HOT Auto and have most of the DIY boltons on it so if you need advice let me know.
Old 05-09-06
abdukted1456's Avatar
abdukted1456 abdukted1456 is offline
My Saabs: 9-5 stg2, 9-5 Aerowagon stg3+, c900T cvt
all the mods you could ever want for your automagic:
me: http://www.cardomain.com/ride/389044
ricot: http://www.cardomain.com/ride/578615
and stevehayes is a modded 9-3 auto also
Old 05-09-06
Mine is as follows
3" DownPipe w/Racecat
Forge 7 series BPV w/brass piston
SMBC -- aids with the low end starts
3" Air Box Mod (can post pics if needed)
Drop In K&N Panel Filter
24mm Rear Anti Roll Bar
Custom FMIC
Meshed upper and lower grills
Do bald tires count as a mod since they are slicks.....
More stuff coming soon.....................
