Seal kit for brake master cylinder reservoir - SaabCentral Forums
Old 29-08-06
szat's Avatar
szat szat is offline
Location: Palm Cove, QLD Australia moved to Canmore, Alberta Canada
My Saabs: Saab 900 Turbo 1989 - sold
Question Seal kit for brake master cylinder reservoir
Has anyone ever used seal kit for brake master cylinder reservoir. Main is leaking for last couple of months. New reservoir cost $100 AUD, sealing kit $30.What is the best option?
Thanks
Szat
Old 29-08-06
AUSSIE900 AUSSIE900 is offline
My Saabs: 89 900 AERO, 88 900 Aero , 93 900 Aero
In the master cylinder repair kit there are are the 2 rubbers that seal the resrevoir outlets to the actual master cyliner , If the leak is actually from the reservoir , the other possibility is the feed tube to the clutch cylinder if you have a manual . Would be surprised if the actual plastic reservoir itself leaked and if it does it must be split , so no kit in world would fix that . SO assuming it isnt split , the kit is the way to go your new $100 reservoir will leak just as quickly as the old one without these seals replaced , , Not sure what part of AUS you are in , I'm Vic , if you are .. VOLVSAAB in keysborough have the kits ... about $ 15 , if that isnt an optin to you , get back to me
Cheers
Les
Old 30-08-06
cdaly's Avatar
cdaly cdaly is offline
Moderator
My Saabs: '92 900LPT, '90 900i vert
They can be variable. If the cylinder bore is in good condition, then a rebuild should work. If the bore is pitted, scored or rusted it's junk. I did one which was fine except that first thing in the morning I would have to push hard on the pedal to get it to move. Once moved all was fine. I've since replaced that one though...
