| Classic Saab 900 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Classic Saab 900 |
With nothing in the boot (apare from the normal tools & spare) the distance from the floor to the wheel arch on my car is 635mm / 25". It has 15" wheels and the S suspension I believe. Can anyone out there with fresh standard S suspension tell me how theirs compares? Or indeed any type of new/newish shocks and springs.
Still trying to decide if I should go with the Killen springs or stock turbo springs. |
| Sponsored Links | ||
Advertisement | ||
It looks low for standard springs, but maybe OK if the Ruby ones were slightly lower. With Sports Springs on the gap would probably be about 1/2 what it is in the picture.
Psytuned 1997 900 Sensonic coupe turbo |
It looks toit like the toiger to me. I've got an S with 15's, don't think it's sagging, and I've got a lot less clearance than that. Bawheid recently bought an S as well, and his clearance is the same as mine. I'll try and post a pic tonight if you want?
MMmmmmmm. Juicy Fruit. |
Tell a lie mate. Mine's is exactly the same. 25 inches to the wheel arch
Yeah, drops a fair bit, but golf clubs is the limit of my normal load carrying, so I've never really worried about it. I think the fact that the 900's so long probably exaggerates how bad it looks.
Go on Nick you know you want the Kilens (and at that price its gotta be worth a try - if you dont like em take em off and sell em on)
Also the above comparisons are only valid if someone has recently replaced their springs and dampers - anything over 6 years old can't count for this test surely? And if you decide to go with stock turbo springs, PM me. G |
I've been having some saggy problems as well. From the ground up, front = 28", rear = 27.75". However, ride height is 3cm difference between front and back, and from the wheel well to the tire the front is 10cm and the rear is 6cm...pretty strange, but it's possible tire inflation is inconsistent (the car is having the clutch repaired at the moment, so tires haven't been checked for the last three weeks). Still, the front looks way too high, and the rear looks saggy.
More importantly, when I have passengers in the car, even going over speed bumps and out of parking lots I bottom out...I think the rear springs are totally worn. I'm looking into lowering springs, 40mm difference. Originally I was going to try stock (Bilstein on mine) dampers with Intrax lowering springs, but after reading several posts, I decided against it, and am going to replace both dampers and springs. Hopefully, I can get my hands on some B&G springs + Koni shocks, about $555 USD. Hopefully, that will fix my bottoming out problem, as well as the crazy high front. li Arc |
Looking at the car today it has that common 'nose too high' stance. Has anyway successfully experimented with regular springs at the back and lowered springs at the front? Or is that just plain dumb
Idea being that you would even up the gaps above the wheels at both ends. At the moment the space between the front wheel and the arch is greater than the rear and its arch. |
When i bought my car the front springs were lowered (unbeknown to me). Not sure what the technicalities are behind all that, but didn't seem to do much to the handling. I do prefer the kilens i aev now, but i'm not sure how new the springs were, or if they had just been cut down. Pic on original suspension....
![]() Oh, and expect an email Nick... G |
Got the rears fitted now - v happy with the set up using standard shocks.
Phil H-B My Carlsson Convertible Project Thread Quote:
I avoided the Kilen springs because I wanted to go up or retain the same height - little did I know I would still have gone up, just not so much (maybe 15mm?). That would have been ok. But my car needs to be a workhorse, and it rides SO much better over speedbumps now
Is my rear end saggy?
Ask your missus Seriously, on apreviouys 9-3 I had the front suspension changed by a "brake, tyre, suspension" shop and they did not put in real SAAB parts and my front was too high.. Thought it would settle down but no.
.Cheers from a little town 3 hours Saabing SW of Huy |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
