Engine coolant fluid - I think I'm loosing it :-) - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 19-03-03
greenphotos's Avatar
greenphotos greenphotos is offline
Location: Flying in my Vector in Basing-St'oke - 2002 9-5 Vector
Default Engine coolant fluid - I think I'm loosing it :-)
My 9000 Aero seems to be loosing engine coolant at a suprising rate, I only re-filled it up about a week ago and it is already down at the min' mark and the on-dash indicator is lit.
Is there a common pipe fault with the system or do you think is it something more serious?
Someone please help as fluid is getting an unwanted expense!
Mark
Old 19-03-03
arjo arjo is offline
Hi Mark : several posibilities.
Head failure :gasket between shortblock and head defect.
Is there any smoke out of the pipe ? 2 A small leak in one
of the hoses( Mostly at the place of a motor connection.
Then you 'll lose fluid when the system is under presure.
You should invest these things.
regards Arjo
Old 19-03-03
Default thanks
Thanks, I'll check them out when it is lite. i get the feeling it may be the pipes, when i listen hard (and the engine hasn't cooled totally, there is a very faint hissing sound coming from the top of the expansion tank. I reckon this might be it.
Mark
