Questions You think are too stupid to ask (9-3SS) - Page 114 - SaabCentral Forums
Old 01-12-10
Aerohead06's Avatar
Aerohead06 Aerohead06 is offline
My Saabs: 2006 9³ Aero
After actually reading some threads on the forum, I definitly wanna go with Vtune over bsr. But when was the Vtune only $750!? The price I'm seeing is $899+shipping!
Old 01-12-10
Diggs's Avatar
Diggs Diggs is offline
My Saabs: 2003 9³SS Linear
Originally Posted by veki91 View Post
Hey giy i have a 2004 93 ARC, and it is leaking oil somewhere between the powersteering bottle and pump. Can the parts be changed individually or does the whole assembly have to be changed? Im a student and i gotta get this fixed asap, the cheapest way!
Thank You
http://www.saabcentral.com/forums/sh...d.php?t=179610
http://www.saabcentral.com/forums/sh...d.php?t=184623
Old 01-12-10
black2.0t black2.0t is offline
New Member
My Saabs: 9-3 turbo
Default message display
i have a question.... how do i get the time for service message off of the display?
Old 02-12-10
movet22 movet22 is offline
My Saabs: 2003 93 Arc
i have a stupid question- what does the air intake do? what are the benefits of a custom one? Is it worth buying/making one? It it really as easy to make as it seems?
Old 02-12-10
Nocturne's Avatar
Nocturne Nocturne is offline
My Saabs: 2004 Nocturne Blue 9-3ss Linear
Garage
The way an engine makes power is by combining air with fuel. More air=more fuel=more power... At least in theory.
In SAAB's it's a bit more complicated due to the Trionic system that manages the engine. You won't really gain any extra power, however, you will gain more of a performance sound (a deep tone when the throttle is wide open), and you'll hear the turbo spooling more clearly.
It's not difficult to make an intake, you just have to make sure that the pipe going to the MAF/MAP (airflow) sensor is the same diameter as what the stock pipe was before you removed it or the car won't like it, at all.
There are threads regarding this, you should use the search feature.
http://www.saabcentral.com/forums/sh...t=short+intake
2004 9-3 Linear Canadian touring package.
16" 10 spoke wheels, dual Xenon, sunroof, reverse parking sensors, auto wipers, homelink auto dimming mirror, heated seats, dual climate control, block heater.
Old 02-12-10
Thanks Nocturne, I have actually read the thread you posted, but still wasn't quite sure as to what I would be doing for my car if I did, in fact, add an air filter. Now that I know, I may just have to give it a closer look! Thanks!
Old 02-12-10
Diggs's Avatar
It's in the SID under the service section.
Old 04-12-10
jordanhurst jordanhurst is offline
New Member
My Saabs: 2005 9-3 Linear 2.0T
Question 2005 Saab 9-3 Linear 2.0t (4dr)
Hey everyone, quick question. If you know anything let me know
Im looking to get this car 2005 Saab 9-3 Linear 2.0t (4dr) oil sprayed under the body, the dealership said it was garonteed no rust for 10 years on this model as there is a coating on the bottom.
Took it to my friends shop today and they checked it over 2 strips are sprayed with a coating on the bottom but nothing else. A few signs of surface rust are there.
Is there any reason why I shouldnt get this oil spray done? My other friend had his g6 GTP sprayed today, and had it done last year.
I live in Canada, Ontario where they salt the roads constantly.
Any ideas??
Thanks a lot!!
Old 04-12-10
pacotaco's Avatar
pacotaco pacotaco is offline
My Saabs: 04 93 arc espresso black
anyone got an explanation to why my sid shows left brake light out when its not? i fiddled with the wires and they look completely fine its just really annoying at this point.
i <3 backroads.
i rule your internet.
Old 05-12-10
JonV JonV is offline
Saabista
My Saabs: 03 Vector
Originally Posted by Wulf View Post
Not really 9-3 specific but probably a stupid question anyways..
Is window tint applied to the inside our outside of windows?
your kidding right!
Old 05-12-10
North's Avatar
North North is offline
My Saabs: 07 Saab 9-3, 2011 95 Turbo4
I have a quick Question.
Recently after filling up my car with gas the low fuel light come on and goes down to empty. I think the problem is with the seal that gas cap is making with the tank.
My question is has anyone else had this problem? and how would i go about fixing this short of buying a new gas cap?
Old 05-12-10
Nocturne's Avatar
Garage
Sounds like you're "sending unit" or "float" as some people call it has stopped working. It has nothing to do with the gas cap.
Price to have the sending unit replaced (part that tells the fuel gage how much gas is in the tank) is about $300 Canadian if you DON'T go to the dealer.
Old 05-12-10
North's Avatar
Thank you for the quick response. The gas cap often feels loose which is why i originally thought that was the problem
Old 06-12-10
quickslvr624's Avatar
quickslvr624 quickslvr624 is offline
My Saabs: Saab 9³ Aero
Garage
My stupid question for the day:
Is it safe to use the handbrake when messing around in the snow (or any wet conditions)? Last night we got a bit of snow and I used it a little when messing around on some side streets by my house, but I was hesitant to crank it all the way to get the rear end out and sliding.
Old 07-12-10
canadiansapper canadiansapper is offline
My Saabs: 07 9-3 Aero SS
I'm not familiar with the 04, but my 07 will detect that the brake light is out and compensate for it with the turn and running lights, so it will still look good but the bulb is out.
Old 07-12-10
xp3's Avatar
xp3 xp3 is offline
My Saabs: '03 Saab 9-3 2.0t
What he said.
Current mods: 14t swap w/ JZW tune, GS Strut Brace, Aero front lip, 9-5 Aero turbine wheels, diy AUX-IN (check out my for-sale-thread)
Coming soon: downpipe/exhaust, Aero body kit
Old 07-12-10
pacotaco's Avatar
so just replace the bulb i mean it does not look like its out at all but i guess it is hahaha.
i <3 backroads.
Old 07-12-10
kimvette's Avatar
kimvette kimvette is offline
My Saabs: 2005 Saab 9-3 Linear
Mine gave me the "bulb out" alert before the lamp was blown. I checked it and sure enough the lamps were still good. The filaments were not broken and there was continuity BUT they had that clumpy look that light bulbs with heavier filaments often get before they blow. I saved them in case I can make the time to compare the resistance of the new lamps to the old ones. I thought it was kind of neat that the car gave an alert about an impending failure!
Old 08-12-10
Lb93 Lb93 is offline
My Saabs: 2003 9-3 Linear
So the traction contro failure message comes on in my car immediately when i turn it on and drive. Ive read up a bit on it but others problems seem way worse than mine. My q8estion is, could it just be a bad sensor? Or does it maybe have something to do with my tires being bad since my car shakes? what should be my next move?
Another question: My cd wont come out. Any suggestions?
Old 08-12-10
Mdave93's Avatar
Mdave93 Mdave93 is offline
My Saabs: 04 93 ARC - Stg III JZW
Garage
Originally Posted by xp3 View Post
What he said.
Ok mine does the same, I checked the bulb... it was fine. I changed it anyways and it still works and I still get the Left Brake Light Failure... Is this a issue with the wiring perhaps?
Although about a week ago I thought Id check again and when I turned on the car the left brake light took 5 sec or so to come on... once on it worked fine. I don't know what the deal is but Im getting tired of hitting clear every time I get in the car.
