I have an 85 900 SPG. I just got the thing out of the shop for a new clutch(500 smackers). Anyway, I drive it home and turn the ignition off. Alittle red light stays on my dashboard. I fiddled with the ignition, thinking maybe I didnt turn it all the way, but the light stayed on. Its the oil light, and it also lights up a spot to the right of the oil space. It is driving me nuts! I have to unplug my batt. every time I go to work. Also, the idiots who did my clutch apparently unplugged a few things here and there, so now my turbo will not enguage fully. about half way up the apc in yellow, then she sputters, so I have to back off it. Also, the large(about 1 inch diameter) hose that is on top of my manifold almost sqeezes flat when the car idles. Maybe a re-enforced hose? I bought the car for 500 bucks, and Ive already sunk almost a grand into it, so I am stuck with my saab. Till the wheels fall off!!
| Sponsored Links | ||
Advertisement | ||
Sounds like the "tech" put some hoses and such back in the wrong places. Do you have a digital camera? Take some hi-res pics, and maybe we can spot a problem.
-Rob |
Here is a common scenario:
The light is caused by a wire, maybe the blue oil pressure switch wire, being plugged into the wrong place on the back of the alternator. Put the blue wire on the switch next to the oil filter. Plug the green and white wire onto the alternator, but not on the the terminal the blue was on, the other one. Replace the collapsed hose. See if the plastic valve next to the coil has 2 wires and 3 hoses on it. |
I'm with Jim on this one. When I replaced my alternator way back when I remember having the same problem with the light on the dash staying on. Finally discovered that some wires on the alt. had been hooked up wrong. Although...why they had to disconnect the alternator or muck about with its wires I don't know
I reject your reality, and substitute my own. - Adam Savage, Myth Busters My Car (flickr) |
They had to prob. move the alt to get to the master cyl. better. cool deal. thanks. Ill check it out today and see if thats it.
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
