I finally got around to installing the rear EBC slotted discs and Greenstuff pads. First 500 miles, not even one sound. But now, for the past 300 miles, they're driving me crazy both when I applying the brakes and moving less than 20mph. Is this going to go away? Also, is there anything I can do or apply until then?
| Sponsored Links | ||
Advertisement | ||
I had a bit of squeaking with mine around 1500 miles, so I did a set of hard controlled braking to bed in the pads and it has eliminated most of the squeeling. Here's a good break-in link: Stoptech
"The procedure is several stops of increasing severity with a brief cooling period between them. Typically, a series of ten increasingly hard stops from 60mph to 5 mph with normal acceleration in between should get the job done for a high performance street pad. During pad or disc break-in, do not come to a complete stop, so plan where and when you do this procedure with care and concern for yourself and the safety of others. If you come to a complete stop before the break-in process is completed there is the chance for non-uniform pad material transfer or pad imprinting to take place and the results will be what the whole process is trying to avoid." |
Unfortunately that's how they are (had them before), but the braking power is really nice. You could put some anti-squeal paste behind the pad to stop it from vibrating. Also, I concur with MarkJ's advice about break-in. It was always fun to feel my eyes push out from their sockets when hard braking.
Are these the only pads you can use with the EBC slotted discs? I'm interested in them but I know I can't tolerate the squeal noise. Can you use other pads? Also, where did you purchase yours? Thanks! |
Aye. Spiel, I wanna ask...do your rotors rust when wet?
solid, you can use any pads you want with the rotors. I chose the EBC Greenstuff because the Saab OEM are soft and I was really disapointed by their short life (19K). I did same as MarkJ, got the pads from GenuineSaab and the rotors from The Parts Bin. Both excellent service, but I did have to wait on the pads for like 10 days to be in stock.
smurkenstein, only the braking surface where the pads rub rust when wet, but the rest of the rotor doesn't. I'll try the hard braking this evening, I hope it works. Thanks Mark. |
Thanks! Do let us know how it turns out.
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
