Need E-Torx sizes for head and rod bolts - SaabCentral Forums
Old 27-06-06
gorper gorper is offline
My Saabs: 86 turbo'd notch & 89T
Question Need E-Torx sizes for head and rod bolts
I'm pretty sure the head bolts are E-16. Can someone confirm? I also need the size of the later conrod bolts.
Thanks...
Old 27-06-06
900t's Avatar
900t 900t is offline
Saabista
Thanks...
Head bolts are E-16.
Old 27-06-06
Thanks, 900t.
Anyone got the conrod bolt size?
Old 04-08-06
Matthew's Avatar
Matthew Matthew is offline
Saab Mad
My Saabs: 900 S Aero Turbo, 9-5 Aero
I thought the rod bolts were not external Torx, but something a bit different. Like a cross between external Torx and flats...
The path of my life is strewn with cowpats from the devil's own satanic herd
Old 04-08-06
nutcase's Avatar
nutcase nutcase is offline
My Saabs: 1978 99T in black; 1983 99GL in Beige
IIRC they're 12 point instead of 6 point (hex). Imagine two hexagons with one rotated 30(?) degrees. A normal 12 point socket should fit fine.
Photo Gallery
