| Saab 9-5 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9-5 |
Just been looking through some of my old tuning manuals and one of them is a guide to installing nitrous oxide to modern engines, so my question is do you guys think the Saab's engine can take this sort of punishment I'm only thinking of maybe 50 bhp blasts (for the odd traffic light grand prix) and also what are the chances of the tronic throwing a fit. But if it is do'able maybe use it with a micro switch on the loud pedal so when it's on full throttle you get a short blast.
Anyway any advice welcome as I doubt I'll actualy do this but I'm a bit bored but it would be intresting |
| Sponsored Links | ||
Advertisement | ||
Now if you were to spray a "dry" shot before the MAF it would be a different story, what I don't know is if this is possible on a turbo car- that's some VERY cold air rushing into a hot turbo- could pose a problem. If it was possible all you'd have to do is make sure you sprayed a small enough shot that it would still be within bounds of what your computer can measure and that your fuel system can dump enough fuel for it. |
If you only sprayed at full throttle and if you used a seperate fuel injector for the added fuel needed it should work. People have upwards of 300 hp reliably on the 2.0L so if should take the abuse provided you do your part and don't fubar the A/F ratio. I'd have the fuel and nitrous spraying as close to the throttle plate as you can setup. Actually that would create a metered air difference wouldn't it. Maybe spray the nitrous in front of the MAF and the fuel on top of the throttle.
Anyway thanks for the replys guys I hadn't thought of dry shots to be honest, trust me to over complicate things. Duncan |
My guess is the VERY cold charge would be VERY bad when it comes into contact with the very hot turbo. Also- with a tuned car I probably wouldn't risk it unless you were to upgrade your fuel system and get a custom tune. Those injectors and pump might already be working hard to keep up with the tune itself- the N2O could just be too much. |
Duncan. |
I'm going to guess that since our cars have a MAP sensor it probably is there primarily for fault checking and is not a primary input into fuel metering. |
That's also why you can only spray "so much" of a dry shot even if your fuel system is up to the challenge. The MAF can only read so much airflow before it goes outside of what is charted in the computer. |
Recently I met up with Kermit, his car is now standard, (engine wise) but has the full eibach pro suspension kit, and that really made a difference to speed, faster into and out of bends, level braking, excellent.
So in the quest to go faster, decent suspension would be a really good idea too
I decline to grant to SAABCENTRAL.COM a non exclusive, royalty free, worldwide, perpetual license to reproduce, distribute, transmit, sublicense, create derivative works of, publicly display, publish and perform any materials and other information I submit to any public areas.... |
one of the problem with n20 is that when it combusts it also produces oxygen. there are kits about for the 9-5.
if you ran a solenoid valve with the correct fuel added after the turbo/intercooler just before the trottel body i cant see there being a problem except for maybe the ecu going a bit mental due to the lamda reading. Eirian |
But I have found this system that looks promising so long as I can combat the cold air/hot turbo problem and fueling http://www.holley.com/16034NOS.asp so I might be able to do it but I might just bottle it as I am not sure I realy want a dead car in the garage. Duncan. |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
