I know its elementary but this is my first attempt at doing my own brakes so bear with me.!
So i decided to save myself a whole bunch of money and change my pads myself. The rotors looked pretty rough so im taking them in tommorow to get them turned. I got the caliper off no problem, 4 bolts off and a metal hanger on each side to hold it up. So now the front of my car is up on blocks and im trying to get those big nuts off the rotors (im assuming this is how you take them off) but my wheels...or rotors rather keep turning so i cant get any torque to the nut. My car is in gear. why is the axel still turning? |
| Sponsored Links | ||
Advertisement | ||
The rotors turn since the differential is there. Note the other side turns backwards as you turn one side.
Solution -> fit wheel on one side, drop it to the ground.
Wait are you trying to turn the BIG nuts in the centre? No don't do that...
You need only remove the 10mm pin for the wheel there. Then it comes right off.
so the little pin that aligns the wheel is all thats holding them on now? |
Ok i removed the 10mm pin....
what about the torx screw on the oposite side? does that need to come out too? |
Sure does... You may need to hit it with a hammer to shock it before you try to loosen it.
and why the hell do they make it so ****** shallow? oh and what does that huge nut in the center of the rotor do? (I know im not susposed to turn it, 900T |
you also have to remove the locating stud to get the rotor off. That is much easier as you can use a wrech, DON'T ROUND OFF THE 10MM nut, man what a mess that was (bad memories).
Fun times: Classic Saab 900 Turbo Convertible, Porsche 911 |
not what i want to do....I was hoping to have the rotors turned and back in by this evening.....darn gremlins.... |
Don't bother getting the rotors cut. Just buy new ones. They are not that expensive and the first time you hit the brakes hard on cut rotors they usually warp.
a guy quoted me $20 to turn both...... I am a very poor college kid |
Rockauto has them at something stupid like 10 bucks apiece. They rape on shipping though.
Yes the torx screw must be removed. Many 900's are missing the torx screw by now May I ask, what are you using to remove the torx screw? Obviously you need a proper size Torx (R) bit. But do you have the good kind, namely something like a socket that fits on the end of a 3/8ths ratchet? With mine I've never had a problem with them. There are also on-car brake turning machines too yaknow. You stick it where the caliper is and start the engine.
No you do not need the screw. Keep in mind you have four big bolts torqued up tight holding the disc flush to the hub - the pin and the torx bit are only to stop it from moving around when you remove the wheel.
drill out that annoying little shallow torx head screw and use a good, hardened steel ez-out. That has always worked for me. Then just put the 10mm locator pin when reinstalling the rotors and don't bother trying to find a new dished head torx...
And lastly, make sure you tighten your wheels bolts back on uniformly (90 ft-lbs at each lug, I believe). edit: 900t beat me to it
2001 325XiT - slow / 1995 9000 Aero - 426whp / 1999 9-3 - stage 3 / 1973 99LE 1994 900 V6 - Team Cougar Bait - 24 Hours of Lemons |
Couple tips, in case someone comes along this thread in a search...
1. Yes, use penetrant. 2. Use a deep, 6-sided 10 mm socket to remove the pins. 3. For the torx bolts, I highly recommend an inexpensive impact driver. Home Despot or Sears have them for about $20. You put a torx bit in the driver, put the bit in the screw, and whack it with a 2 or 3 pound hammer. Works very well and is well worth the ~$20 (compared to the time/energy/frustration of dealing with a stripped torx). Here's what I'm talking about: http://s7.sears.com/is/image/Sears/00947641000 4. Put some anti-seize on the bolts when you button it all back up. |
The rotor skimmer grips the rotor while you throttle it and that's how it gets skimmed. Better than removing it, skimming it, and finding out the plane is off when it goes back in. But you can't do it for the rear rotors.... James
"I will never join a club that accepts people like me as members..." |
what pins are you guys talking about? Locator pins? I've done my brake a million times and feel like a bit of a gooober.
I got them off this morning. got a bowl of cereal, headed out to the car with a drill and the easy out and in 3 minutes I had both off. lord knows ill have another million questions when i try to put it all back together this afternoon... |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
