1991 Saab Fuse Diagram - SaabCentral Forums
Old 18th June 2006
Renaemo Renaemo is offline
My Saabs: 1991 900 Turbo Covertible
Default 1991 Saab Fuse Diagram
Does anyone have this scanned? I just bought a 1991 Saab convertible Turbo 900 It came with no manuals and the convertible top just stopped working. Does this have a fuse? Hope this isnít a stupid question.... but truth be told I am a chic... (Women mechanics donít get mad that I am using my being a girl as ignorance in the car dept.) But bottom line is I am a total wimp and hate to get my hands dirty!
THANKS!!!
Renae
Old 18th June 2006
ursatz's Avatar
ursatz ursatz is offline
My Saabs: '90 900 turbo convert
There is a fuse on a panel under the rear seat (three or four bolts to remove the seat - easy). On a 1991, the fuse is #1 for the convertible top.
Don't forget to look in the engine compartment (passenger/right side, I believe) for an in-line fuse. It should be clearly labled as such.
I really belive that the problem is more likely to be the switch. It should be removed and cleaned. You may find that the contacts are just dirty, or maybe a simple reseating will help. This was the case when I first bought my convertible.
When I cleaned all of my switches (a good idea) the switch illumination stopped working. There are plenty of posts on this forum and here (under slow window syndrome) on the switch-cleaning subject.
Good luck.
Old 18th June 2006
cdaly's Avatar
cdaly cdaly is offline
Moderator
My Saabs: '92 900LPT, '90 900i vert
Also the handbrake must be on for the top to work. If you don't get a brake light on in the dash, it won't go...
As for getting your hands dirty, there are these brilliant vinyl gloves you can get... And you'll save a stack of money doing your own repairs. Lots of good advice and help to be had on here and even one or two girly-girl mechanics!
Oh, and welcome.
Old 18th June 2006
Thanks so much... I bought gloves!! Wink Wink.... I am pretty tough just hate when my hands are dirty! Thanks for all the help I do love this little car. another quick question do I put the transmission fluid in the place where the dip stick is?
Renae
Old 18th June 2006
chaka chaka is offline
My Saabs: 87 Turbo, 91 Turbo Conv
I learn something new here everyday.
Old 19th June 2006
900t's Avatar
900t 900t is offline
Saabista
Hehe, "ok well to raise or lower the top you have to pull the handbrake, honk the horn three times and jump up and down in the seat".
Old 19th June 2006
Ezra's Avatar
Ezra Ezra is offline
My Saabs: T16-89,T16-91,900S-92,
Hi Renae, another girl mech who don't like getting her hands dirty! However, it would help a bit if you could let us know
1) did it work when you got it? If so, any noises when operating, if so, what!
2) is there any noise when operating the roof switch, such as a clicking, or is it completely dead; you can test this without the engine running as long as the handbrake is on, and the cars in P (with ignition on )
3) getting the seat is up is straight forward, may just be held in situ by two lugs, in this case its a pull up from the bottom of the seat (I actually start it off by pulling from the back of the seat where the seat meets the backrest). It MAY have two bolts where the lugs could be, so check carefully as Ursatz said.
4) whilst you're there you may as well check the hydraulic fluid level in the motor on the opposite side of the seat well to the fuse box - you can't miss it. A mirror and torch would be handy as it'll be a bit dark with the hood on. Should be at the LOWER mark level with the top up. Mine stopped working completely when the fluid had dropped too low but I could hear it trying to work hence earlier question.
Good luck Ez
Old 19th June 2006
SteveTheFolkie's Avatar
SteveTheFolkie SteveTheFolkie is offline
My Saabs: 1987 900 8V
To quote Elwood Blues .... "yep"
steve
Old 19th June 2006
Thanks guys and ladies . I turned off the Hydraulic so I can lower it by hand. It worked when I bought it. A little slow but no major noises. Now it makes no noise, no clicks, no nada.
Thanks for the tranny fluid answer, guess I have to invest in a funnel...since that is one tiny hole....hehe
Renae
Old 19th June 2006
4saabstoomany's Avatar
4saabstoomany 4saabstoomany is offline
My Saabs: 86 900T | 08 Saab TurboX
are we sure she's not talking about the motor oil dipstick? Some of those year models (like my moms old car) didn't have a tranny dipstick.... so we might want to check up on that.
Is this dipstick you're talking about on the passenger or drivers side of the car?
Branden
Saabs: If it ain't broke, meddle with it more.
Old 19th June 2006
... as it has the "tiny" hole I'd have to presume it's for the gearbox and not the crankcase ....
Old 19th June 2006
This is in the front of the car. The motor oil dipstick is marked pretty clearly. (Thank Goodness)
Thanks though for double checking.
Renae
Is there any instructions on this site for how to change the Spedometer cable?
Thanks!!!!!
Old 19th June 2006
Thanks!!!!!
Uh oh.. It's starting already That was quick!!!
Branden
Old 19th June 2006
cdaly's Avatar
Moderator
Useful to mention that it's an auto trans...
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
