shocking experience - SaabCentral Forums
Old 15-06-06
Juneau Juneau is offline
My Saabs: 85 8vT, 88 16v, 87 8v, 87 16vT, 92+93
Default shocking experience
Give me some feedback on this event:
1987 8v non-turbo
I've been attempting to solve a "rich running" problem. Read alot of threads about the area. I decided to pull the plug wires while at idle to see if a cylinder of not firing. Put on gloves and used a special pliers (insulated) to pull the wires from the plugs. Man, I barely got the first wire off the plug and there was sparks dancing all over the outside of the rubber plug boot, not to mention I was dancing while the high voltage pulse went through me! Wow, shocking. Anyway, I'd say this was not normal. I am thinking the plug wires are shot. I should be able to bare hand remove these and not get bit...right? There shouldn't be any voltage dancing on the outside of the boot-correct? I couldn't get the boot out very far for obvious reasons.
Please let me know if I am on the right reason to replace the wires.
What are the best plug wires to purchase? Original Saab (starts with a "B" manufacture)
Thanks
Pete
Old 15-06-06
Saab Driver Saab Driver is offline
My Saabs: 1986 C900i 8V NA
Default Electronic Ignition Sytems
Electronic Ignition Systems run at much higher voltages than the old conventional systems. Exercise caution - they can be dangerous.
Old 15-06-06
Si's Avatar
Si Si is offline
My Saabs: Sensonic NG900T, a gagle of rusty c900's
I've had a HT lead shorting to the block, best off replacing plugs, leads, cap & rota as they are all reletively cheap.I think i got the bougicord ones which seem fine.
Psytuned 1997 900 Sensonic coupe turbo
Old 15-06-06
Tomarse's Avatar
Tomarse Tomarse is offline
My Saabs: LPG '80 99GL, '80 99T 2dr, LPG '93 ng900
you should be able to remove leads by hand while it is running and not get shocked!
you could try running the car in the dark and see if you can see any sparking anywhere?
Old 15-06-06
900t's Avatar
900t 900t is offline
Saabista
Bougicord! Again never had a similar issue to you.
Old 10-07-06
Matthew's Avatar
Matthew Matthew is offline
Saab Mad
My Saabs: 900 S Aero Turbo, 9-5 Aero
I got an HT shock from the shorting king lead on set of Magnecor leads once. Now I just switch off the ignition before changing the leads!
The path of my life is strewn with cowpats from the devil's own satanic herd
Old 10-07-06
nutcase's Avatar
nutcase nutcase is offline
My Saabs: 1978 99T in black; 1983 99GL in Beige
I always turn off the ignition before fiddling. The one exception is when making small adjustments to the dissy position when I use the vac capsule to turn it - 1) it acts as a slamm lever so can leave the clamp done up slightly so it doesn't move by itself and 2) it's earthed so I'm not going to xap myself
Whilst you're supposed to be able to touch ignition leads with the engine running, it only takes a bit of dirt to allow a little conduction leading to a zap.
Photo Gallery
Old 11-07-06
Rich3Saabs's Avatar
Rich3Saabs Rich3Saabs is offline
My Saabs: 1990 900S 5-Spd
Default Did Juneau that you could ruin the electronics by removing the plug wire?
Removing spark plug wires will sometimes ruin your electronic ignition system. Voltages will increase to make the jump thus exceeding the safe limits of the electronics. Use a dummy spark plug grounded to the block to handle to electrical load of the particular lead you are experimenting.
No need for the insulated pliers.
Old 13-07-06
tonyw's Avatar
tonyw tonyw is offline
My Saabs: 1989 Saab 900i 8v Auto 4 door
Hey Juneau,
You solved that rich running problem yet? I have an '89 8v auto which up to now has had pretty bad MPG , but that seems to have been fixed by replacing the thermo time switch. I had already replaced the cold start valve and warm-up regulator (after the usual tune up, plug change/gap check, oil change, air + oil filter change, tyre pressure increase, lead changes, etc), but they didn't improve the situation.
I'm now getting an extra 100 miles to a tank of fuel, than I was getting when I bought the car. With UK fuel prices, that's worth the time and investment (or will be in a year or so's time! ).
