viggen turbo lines - SaabCentral Forums
Old 13-06-06
nastysaab nastysaab is offline
My Saabs: 2000 Viggen 5dr
Default viggen turbo lines
so i got a new tdo4hl-15t off ebay. now i need to know what lines to put it on my ng 900 .. can i make the lines. need feedback from you guys that have done this
Old 14-06-06
please guys who has done this already
Old 14-06-06
touche6784's Avatar
touche6784 touche6784 is offline
My Saabs: 2002 9-3 SE
i believe you would need something like this
http://www.genuinesaab.com/catalog/p...roducts_id=424
Old 14-06-06
no im not looking for the intercooler lines im looking for the water and oil lines for a viggen turbo to put into my ng900
Old 14-06-06
mike saunders's Avatar
mike saunders mike saunders is offline
Saabista
My Saabs: N/A
The 00-02 9-3 SE uses the same TD04 turbo. Find a junked SE from that year and ask for the lines...
Old 14-06-06
Soon To be Saab Owner Soon To be Saab Owner is offline
My Saabs: 1999 Saab 9-3 2.0 Turbo..T5 of course!
http://www.maptun.com/webshop/shop_i...04500692dcc006
This is the kit that Maptun sells. It's like 200 dollars. I used this and it was a perfect bolt on. Has anyone done anything else? I have heard you could fab something else with thicker washers, but I didn't quite understand how.
1999 Saab 9-3 S 2.0 Turbo 5-spd.
Old 14-06-06
dip's Avatar
dip dip is offline
My Saabs: 1999 9-5
The only TD04 line you can actually benefit from on NG900 is the coolant return line. I'd say just get four oversized 1/2" copper washers and use all your existing lines with 12 mm banjos on TD04. More info here.
Old 14-06-06
96redTurbo's Avatar
96redTurbo 96redTurbo is offline
My Saabs: 1996 900SE 2.0Turbo
on the subject of the td04 turbo, how much of a perfomance increase is it to the ng900s? i've been thinking about purchasing a new turbo myself.
Old 14-06-06
dip's Avatar
dip dip is offline
My Saabs: 1999 9-5
Performance increase of the turbo alone? Close to none! And a slower spool-up as a bonus. With matched software, however, it's a whole different story.
Old 14-06-06
96redTurbo's Avatar
ah i see. it would most likely be a save up project for me cause i know a software change/ecu tune isn't exactly cheap. definately seems like something to start working towards though. thanks for the info
Old 15-06-06
stromer's Avatar
stromer stromer is offline
My Saabs: 1999 9-3 SQR stage IV - 2002 9-5 Aero
I posted a couple threads with the sizes when I did my td04 swap into my 99. Like dip said, only the coolant return line is the same. So hold onto that one!!
I used braided stainless lines with AN fittings from summitt and it worked great.
Old 15-06-06
do you have any part numbers from summit and whats AN fittings so there are 4 lines and i can keep the coolant return line so i have to get the remaining 3 lines?
