Sunroof not working - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > 9000 Workshop
9000 Workshop 9000 (1985-1998) Technical Forum
Old 6th June 2006
tehweej tehweej is offline
My Saabs: 1992 Saab 9000 S
Default Sunroof not working
I have a 92 9000 s and the sunroof does not do anything when i push the switch. No noise or attempted movement at all. I can open it the crank. Any tips for troubleshooting would be appreciated.
Old 6th June 2006
microcat36's Avatar
microcat36 microcat36 is offline
My Saabs: Four Saab V6's and a 2.3 FTP
Obvious one, have you checked the fuse, if not it might be the switch, failing that the motor could be u/s.
Five Saab V6's, So quiet, So smooth.
Old 6th June 2006
I have already checked the fuse, and will check the switch. Thanks!!!
Old 6th June 2006
So it is the motor. Now how would one go about replacing the motor?
Old 6th June 2006
9000freak's Avatar
9000freak 9000freak is offline
My Saabs: 1995 Saab 9000 CSE 2.3FPT Manual 180k
Try swapping the switch before you replace the motor. Sometimes, over the course of years and several accidental spills, the switches inside become corroded to the point at which they no longer function. This is what happened to me and a switch from a junkyard cured the problem.
Old 6th June 2006
I cleaned the switch and now i hear a click coming from right by the manual crank box. So it seems that it is indeed the motor. Any tips or tricks for replacing the motor?
Old 6th June 2006
ltz ltz is offline
My Saabs: Former, 900t (82), 9000 CSE T
You should be able to find a pretty good "howto" in the workshop manual for removing the inner roof.
While you're at it. I can recommend you to take a look at the inner side of your roof where the sunroof "slides/hides away". I had to fix the entire inner part of my roof because of bad rust protection from the factory. The rust had almost gotten all the way to the outer side of the roof.
Perhaps these problems are most related to sweden and the salt on the roads here.. But it wouldn't hurt to check if youre there..
If I find any, I might be able to get you a picture of the corrosion I had..
Old 7th June 2006
93SaaB9000CS's Avatar
93SaaB9000CS 93SaaB9000CS is offline
My Saabs: 1993 9000 CS 5-spd
I too had that problem, i removed the relay and opened it up.
Found that a part from the coil was melted somewhat and sticking up
and the switch inside the relay wasnt making contact.
so do check the relay before you try changing the motor.
Also, upon changing the car battery, the sunroof now works alot better,
seems it might not have been getting enough power.
things i went thru while trying to diagnose the problem.
sounds weird enough but that's what i went thru.
EDIT: Btw hello everyone
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
