91 Saab 9000 possible vacuum hose problem - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 04-06-06
dak83 dak83 is offline
My Saabs: 2002 Saab 9-3 SE 5 speed
Default 91 Saab 9000 possible vacuum hose problem
I'm a newbie.....I have a 91 saab 9000 turbo and while pulling into the driveway, the car turned off once the rpms got down to about 1000(there was no studdering or funny noises, it just shut off)...provided i keep the rpm's high the car will drive (it seems to idle ok as well, from a cold start)...i've eliminated the ignition cassette and was told maybe a vacuum hose...i looked and don't see any damaged hoses
Old 04-06-06
its_tricky83's Avatar
its_tricky83 its_tricky83 is offline
My Saabs: 9000 CD FPT '91
Or the Bypass Valve stuck open!!! Quite common.
Old 04-06-06
Superaero Superaero is offline
My Saabs: 1997 Aero manual
Or a dirty throttle plate which interferes with the AIC valve's ability to maintain a constant idle speed. This is more common on older SAAB's. Fuel Injection throttle plate cleaner is the solution here, assuming the hooter valve and all other vacuum lines are OK. The dipstick tube and cap leaking can also cause problems.
