crank it up - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 03-06-06
gorgeous_shaun gorgeous_shaun is offline
My Saabs: 9000 turbo 16v
Default crank it up
i have a 2.0 9000 FPT its a '90. is the difference between the displacement of the 2.0 and 2.3 the stroke of the crank or the bore of the cylinder?
thanks, shaun
Old 03-06-06
Marrk's Avatar
Marrk Marrk is offline
thanks, shaun
Its a longer stroke, the pistons are the same diameter.
Old 03-06-06
if i change the crank over then i got a 2.3?
Old 04-06-06
Superaero Superaero is offline
My Saabs: 1997 Aero manual
Connecting rods may not be the same. Compression ratio will be around 15% higher unless you change the pistons or head (not sure how SAAB does this).
More importantly, the 2.3 requires balance shafts to run smoothly. It is generally accepted that above 2.0 litres displacement a four cylinder vibrates excessively without balance shafts.
Of course several big four cylinder racing engines have been built without balance shafts (invented by Mitsubishi and most if not all engine manufactruers use a Mitsubishi license). Offenhauser Indy engines were huge fours. Ferrari built a 3.0 four. Porsche did also but used Mitsu licensed balance shafts for their production 944/968 engines.
Old 04-06-06
thanks for the reply, i totally forgot about ballance shafts! i have been reading up on tuning saabs and found its better just to keep the shorter stroke and more boost, all the trouble i will hve to go through ballance shafts, head, piston con rods all for an extra 300cc few horses and pounds of torque. even though these bits need changed in the tuning process its not worth it just now. just made up the extra power anyway with an MBC i installed earlier. very pleased with that! must be over 200 bhp and all for £67 for the car plus £5.50 for the MBC, unbelievable
