Acc - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9000 > Saab 9000 Workshop
Saab 9000 Workshop Saab 9000 (1985-1998) Technical Forum
Old 31-05-06
9000freak's Avatar
9000freak 9000freak is offline
My Saabs: 1995 Saab 9000 CSE 2.3FPT Manual 180k
Default Acc
Seems like when it barely gets hot, everyone starts asking about how to fix their climate control, myself included.
My ACC unit has been acting funny lately. It will randomly get power and then lose it. Like it will be working fine for hours on end and then all of a sudden, it looses power. None of the buttons work and the display doesnt either. I have to take the unit out of the dash, which is a PITA because I work my way up from the ashtray taking things out, which is complicated by the fact that I am driving at the same time, but oh well.
I can press the connector into the back of the unit with a fair amount of force and it will turn on and run fine. then it will die again.
Any suggestions? maybe a new acc unit from a junkyard?
Old 05-06-06
9000freak's Avatar
Any Ideas?
Old 05-06-06
djtaylor djtaylor is offline
My Saabs: 9000 Aero
If that fixes it then it sounds like a poor connection that cleaning the contacts might help with.
You could try an alternate ACC unit but given that yours works when you re-seat the connector, I'd go with contact cleaning first.
David.
Old 05-06-06
9000freak's Avatar
Ive tried cleaning the contacts and I also put di-electric grease to help the issue, It didnt help. Ill try an alternate unit.
Old 15-06-06
9000freak's Avatar
UPDATE: The grey and red wire at pin 30 was not getting a good contact. I tried shoving some di-electric grease in the front: didnt help. So I put quite a bit in the back where the connector and the wire come together. Works like a charm
Old 15-06-06
Jim Mesthene Jim Mesthene is offline
Dielectric grease is called that because it doesn't conduct electricity. It is not recommended to improve poor contact, but to prevent corrosion and damp.
Old 15-06-06
9000freak's Avatar
It worked. However, if it does still pose a problem, what kind of substance should I use?
Old 15-06-06
Either the tab that holds the terminal in the connector is weak or missing, or the terminal contacts are distorted. Either way, bending or pushing the contacts back in place is the right approach.
You managed to narrow down the problem and identify the cause, that's the hard part. If it fails again, pick at it with a probe until you get good contact. If it's working well now, ignore me and my advice.
