Oil Pressure / Temp monitoring - SaabCentral Forums
Go Back   SaabCentral Forums > Saab 9-5 Mk.I, 1998-2009 > Saab 9-5 Performance, Mods & Tuning
Saab 9-5 Performance, Mods & Tuning Covers Tuning & Performance modifications for the Saab 9-5
Old 29-05-06
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Default Oil Pressure / Temp monitoring
I think we have talked before about how useful it would be to have an oil pressure and/or oil temp gauge, this sandwich plate thingy, would enable this plus allow for an additional oil cooler if required.
Looks like Scoobies use them.............anyone had a go with one of these?
http://cgi.ebay.co.uk/GAUGEPLACE-OIL...QQcmdZViewItem
Oil filter sandwich plate:
Any thoughts?
Old 29-05-06
Kermit's Avatar
Kermit Kermit is offline
Saabista
My Saabs: Citroen C5 2.2HDi
Ooohh interesting, kill two birds with one stone. Oil temp sensor and an additional oil cooler if needed. Go on Chris, you know it makes sense.
Old 29-05-06
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Three birds me Olde Matey!
Oil temp / Oil Pressure & Extra Oil cooler
Old 29-05-06
XAAMOTTOMAAX XAAMOTTOMAAX is offline
My Saabs: 2003 9-5 Aero
You have to remove the starter to get to the stock pressure switch. This might make fitting anything larger very difficult. Something to consider....
Old 29-05-06
Shiston Shiston is offline
My Saabs: 1998 9-5 SE 2.3lpt sedan
Isn't here already an oil cooler, why not just replace that with a bigger one?
I suppose to that with a bigger oil cooler, or even 2 coolers, then that means more oil required which is a good this as well.
Old 29-05-06
BrianS's Avatar
BrianS BrianS is offline
My Saabs: 2001 9-5 Aero
I tapped the stock one with 3/8th NPT and ran the lines to my Setrab cooler out front. Works great.
Old 29-05-06
Raven18940's Avatar
Raven18940 Raven18940 is offline
My Saabs: 2001 9-5 Aero 5spd
It's times like these I'm glad I'm stock.
Old 30-05-06
denmaster denmaster is offline
Does anyone here know the size of that o-ring on the oil filter housing (the big bolt to the right of where the two blue fittings joining the oil cooler hoses go? mine's seeping from there
--lg
'84 c900 CD + 16v Lucas + RRFPR + Greddy External Wastegate + HKS EVC + 3" Head to Toe.
'82 c900 3dr
Old 30-05-06
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Why remove it? We know its poor at sensing low pressure, i.e lights when its very, very low
The feed for the new (and accurate) oil pressure gauge would come from the sandwich plate above.
My only question would be, where to mount the gauges, as I dont like those pillar pods
Old 04-06-06
dann1940 dann1940 is offline
My Saabs: 1999Viggen LB, 2005-95 Aero wagon
Chris interesting comment about the pillar mount. I want to add an oil pressure guage and a volt guage but can't seem to figure out a place to do the mounting. Maybe some of our forum members who have addressed this problem could post some pictures? I'm trying to find a solution that does not require hacking up the dash board or panel. The "a" pillar mount seems like an easy solution but is not my first preference. There may be some digital solutions that would offer smaller guage faces and require less fitting modifications to the dash. Thanks, Dan
Old 04-06-06
Raven18940's Avatar
--lg
Sadly I don't know, but I know that's the oil thermostat housing. Perhaps the dealer will have a replacement.
