pinking (knocking) - SaabCentral Forums
Old 20th May 2006
Dean O's Avatar
Dean O Dean O is offline
My Saabs: 2 x T8 specials & 2 cat D write offs
Default pinking (knocking)
APC solonoid connected: boost gauge only goes to half yellow. (still chatters on warm down & stops when brake pedal pressed)
disconnect APC solonoid: boost gauge goes to red line ok but engine starts pinking at half yellow - the same max boost spot as when solonoid connected. shouldn't it only pink higher up, much higher up?
Old 20th May 2006
cdaly's Avatar
cdaly cdaly is offline
Moderator
My Saabs: '92 900LPT, '90 900i vert
I don't know the details but you should be thinking about timing, vac advance/retard and fuel quality. Dunno what else...
Old 20th May 2006
Dean O's Avatar
ta cd ( ) Yep, I've always associated pinking with advanced timing, but isn't that usually accompanied by quicker acceleration? & its a bit sluggish if anything
Old 20th May 2006
ubermich's Avatar
ubermich ubermich is offline
My Saabs: 1993 900 vert, 1990 Ford Bronco(4 sale)
If the timing was *way* off, I would think it would become sluggish. IE: if it's too far advanced it would be pushing the piston back long before TDC which would kill power output.
Truck: 90 Bronco (For Sale)
Car: 1993 900 vert, bone stock
Old 20th May 2006
Dean O's Avatar
good point!
Old 21st May 2006
Saab Driver Saab Driver is offline
My Saabs: 1986 C900i 8V NA
Default Detonation
The only likely point not covered is fuel/air ratio too lean ??
Old 21st May 2006
ubermich's Avatar
How do you test this?
Old 22nd May 2006
Default Knock/Detonation
The AFR can be checked with an AFR Meter which all good auto workshops would have. This would be last on my list, after checking items previously mentioned,viz., octane rating of fuel, spark advance , engine temp , spark plugs of correct heat range. With ref to spark plugs make sure also pinging has not caused any physical damage. Wrong plugs may cause pre ignition leading to detonation ( pre ignition is an entirely different problem usually ).
Old 23rd May 2006
Matthew's Avatar
Matthew Matthew is offline
Saab Mad
My Saabs: 900 S Aero Turbo, 9-5 Aero
Something's not right there - when the APC solenoid's disconnected the car should be restricted to base boost only. Has the wiring been monkeyed with?
If a previous owner's not been able to get the car to boost properly, then they have bodged it. It does sound like the APC box has been taken out of the equation.
Old 23rd May 2006
Dean O's Avatar
I've misled everybody - sorry fellas
In light of Matthew's comments, I re-read my initial post & its plain wrong I'm afraid.
I did unplug the solonoid for a trial run in trying to get to the bottom of the warm down chattering BUT had reconnected it before
DISCONNECTING THE 3RD OUTLET PIPE (driver side) for the run that produced the pinking from 1/2 yellow thru to red border! - again, sorry.
Old 3rd July 2006
Dean O's Avatar
sorry to drag this up again, but this problem remains 'as was' despite new engine fitted
could it be the solonoid itself that's faulty? could swap the one off me T16 if its worth it.
Old 3rd July 2006
Si's Avatar
Si Si is offline
My Saabs: Sensonic NG900T, a gagle of rusty c900's
Have yo got another APC you can swap to see if it continues?
If it does then you've got to start with the pressure transducer really, it's under the dash but you can test it from the APC plug.
1997 900 Sensonic coupe turbo
Old 3rd July 2006
Tomarse's Avatar
Tomarse Tomarse is offline
My Saabs: LPG '80 99GL, '80 99T 2dr, LPG '93 ng900
I'm having loads of trouble with the fueling on my 99T. I've got an air/fuel gauge to test it with.
I've changed the entire fuel system now and am thinking that perhaps all my fuel pumps are faulty
Old 4th July 2006
Dean O's Avatar
I'm beginning to think mine's running lean now as well
dunno whether having to unplug the CSI to get her to start is a separate issue, but I've noticed two successive mornings now that I have full boost UNTIL normal running temperature is reached & then it starts pinking about half way up the yellow & obviously won't then boost beyond that.
Tom, when yer finished with Si's gauge, will ya post it to me
Old 4th July 2006
Tomarse's Avatar
That is exactly what mine was doing a week or so ago!
Then i started messing with the mixture to richen it and changing bits around (which made no difference). Now it has gone really lean like i said in my thread.
Sonnett1 said that he had found somewhere selling cheap bosch fuel pumps, but im still waiting for him to tell me where this place was so i can order one for myself!
Old 4th July 2006
Dean O's Avatar
you mentioned yer fuel pump, Tom
again, dunno whether its significant but when I turn on the ignition, the pump 'priming' noise or is it the relay buzzing for a few seconds? whatever the noise is, it only happens maybe 50% of the time now, whereas I'm fairly sure it always used to be 100%.
Old 4th July 2006
Orca Orca is offline
My Saabs: ܁
Does your vac advance capsule on the distributor work? That has an obvious effect on the timing when in boost. The other thing is to make sure your fuel pump has a good ground. Mine buzzed most of the time and completely stopped once grounds had been cleaned up. The quiet was quite eery at first
Old 4th July 2006
Dean O's Avatar
don't spose you could advise me how to test the capsule, Orca just notice yours is a T8 special too
my fuel pump (assuming it's that which is supposed to make a noise when the ignition is 1st switched on) only buzzes for about 2 seconds then not at all, which I think is normal. the problem I'm having is that it no longer buzzes every time I turn on the ignition.
actually I have a working spare distributor so I'll swap that to test if the vaccuum advance is working
Old 4th July 2006
Tomarse's Avatar
Dean - you can take the vac advance/tard capsule off the dissy - its 2 screws.
To test if it retards under boost like it is supposed to, get the car running with a timing light on it then pump up the feed to the capsule with a foot pump. the timing should change.
I went through all this on mine first and it was working fine.
I dont think my pumps run when i turn the key either, though it used to. Mine is also very hard to start - I have to crank it once. then turn it off for a second and then crank it again to make it catch. wonder if it is all down to the pump?
Old 5th July 2006
My Saabs: ܁
Their failure is simply that the diaphragm no longer seals the unit, so suction and pressure no longer actuates the arm. The simplest method is to remove the vac hose from the throttle end, block off the open holes, fire up the car and fire a timing gun at it. Apply suction to the hose connected to the capsule and see if the timing changes ... then pressure ...
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
