Strange Electrical Problem - SaabCentral Forums
Old 19th May 2006
AMF AMF is offline
My Saabs: 1972 "96", 1999 9-5 V-6, 2006 9-3 2.0T
Question Strange Electrical Problem
My 1999 9-5 SE has a strange electrical problem. When the car is running, the right rear directional signal light stays brightly lighted. (As well as all the other lights that should be lit) When the directional stalk is set to turn right, the right rear directional light does not blink (because it is fully on). In addition, the left side marker light does not light......however, if you set the directional stalk to turn left, the side marker light will blink as it should. All the other lights seem to be working ok. The car has never been in any accidents or had any re-wiring. Any body have any experience with this? Any assistance would be appreciated. Thanks.
AMF
Old 20th May 2006
Kermit's Avatar
Kermit Kermit is offline
Saabista
My Saabs: 04 9-5 Vector 2.2Tid
Sounds like a dodgy ground wire, you'll need to get a voltmeter out and check around the car.
Old 21st May 2006
BMW_killer's Avatar
BMW_killer BMW_killer is offline
My Saabs: 99' 9-5 SE, 89' 9000 CD turbo
when one of my brake lights went, i replaced all my rear lights (including my rear fog lights). as it turns out, my right rear fog light was out also! but not out as in burned out, out as in not in the car! the hole where the light should have been was blocked by a piece of plastic attached to the light tree. . this obviously happened at the factory, and i was not a happy camper. so my guess is that it's just a faulty wire, but i'd check all your other lights too
Old 21st May 2006
Cambio's Avatar
Cambio Cambio is offline
My Saabs: '99 9-5 SE 2.3lpt, 5spd, JSP Stage 3
I'm not understanding if you mean the inside (dashboard cluster) lights or the real directional lights outside the car...
1999 Saab 9-5 SE 5spd Silver-Green/Sand Beige
Taliaferro Open Intake - Forge Motorsport 007 Recirculating Dump Valve - Remus SaabSport Exhaust - Aero Clutch and PP - Taliaferro Transmission Mount - JSP 3" Downpipe w/ Racecat - JSP Stage III Tuned - Koni Fully Adjustable Shocks - Aero Springs/Sways - Silicone Vacuum Lines - PCV Update #6 - Brand new Fuel Tank and Walbro 255lph Pump - Autometer Boost Gauge - MHI TD04 Big 19T 6cm2 Turbo Awaiting Installation
Old 22nd May 2006
Kermit's Avatar
Saabista
All 9-5's come with 1 rear fog light as standard, punching out the plastic lug is a recognised modification some make. Its not a legal requirement to have 2 fog lamps, just A rear fog lamp.
Old 23rd May 2006
AMF AMF is offline
Lightbulb Stange Electrical Problem Solved
Your not going to believe this one. I pulled out fuse 35 so that the daytime running light feature would not work... as two of the lights....the front right directional and the rear right directional were burning so bright as to heat up the light assembly......So, now the fuse is out right? When you activate the directional signal the headlights flash to the rythem of the flasher. I told you this was wacky. So to recap.....before the fuse was removed, with the engine running, the back right directional was on....not flashing,....very bright. The right front directional was on, not flashing......very bright and the side marker light was on! Following so far?......
I pulled the fuse so as not to overheat the light fixtures, and headed to the dealer. They found the problem in seconds (obviously they have seen this before).....Here it is: The front right directional signal bulb has two contacts which mate with the socket contacts (Dual filament bulb) Those little lead contacts had melted together and completed a circuit that somehow causes all the crazy actions I described. Bulb changed .......problem GONE.
I hope this info helps someone......cause this was a new one for me!
AMF
Old 23rd May 2006
Kermit's Avatar
Saabista
Wohoo a cheap fix from the dealer, how much was the bulb $60?
Old 23rd May 2006
Chris 9-5's Avatar
Saab Sage!
My Saabs: .
Originally Posted by AMF
Your not going to believe this one........................................I hope this info helps someone......cause this was a new one for me!
AMF
Nope dont believe ya
Old 17th February 2009
valrune valrune is offline
My Saabs: 00 95 2.3 5sp
AMF
YES!!!!!!!!!!! This just helped me tonight!!! I had the same problem so I pulled the right front turn signal bulb and there it was. The two little soldered contacts had come together causing a short so I used a razor knife and(carefully) separated them. I reintalled the bulb and it works perfectly !
See what happens when you use the search function!!!
P.S. Total cost of repair............$0.00
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
